Solving Dynamics Problems: Ramp and Friction Forces
In summary, the conversation involved a problem involving a box on an inclined ramp with friction forces. The problem asked for the largest and smallest forces that can be applied to the box without causing it to move. The conversation discussed the correct equations for solving these forces, taking into account the coefficients of friction and the angle of the ramp. The conversation also mentioned the effect of the normal force and the kinetic friction force on the solution.
James_fl
29
Hi everyone,
I'm having a problem in solving dynamics problem involving ramp and friction forces. I'm wondering if anyone could give me some help to check my answers and give some hints on how to solve the problem :P
Anyways, here is the description of the problem. If you find it unclear, please let me know:
A box with a mass of 22 kg is at rest on a ramp inclined at 45 degrees to the horizontal. The coefficients of friction between the box and the ramp are [tex]\mu_{s}=0.78[/tex] and [tex]\mu_{k}=0.65[/tex].
a) Determine the magnitude of the largest force that can be applied upward, parallel to the ramp, if the box is to remain at rest.
b) Determine the magnitude of the smallest force that can be applied onto the top of the box, perpendicular to the ramp, if the box is to remain at rest.
This is how I solved (a):
[tex]F_{app}[/tex] is the magnitude of the force applied to the box upward and parallel to the ramp.
[tex]F_{g}[/tex] is the magnitude of the gravity force.
Fsmax
[tex]F_{s, max}[/tex] is the maximum static friction force.
[tex]\theta[/tex] is the inclination of the ramp.
If [tex]F_{app} > F_{s, max} + F_{g} sin \theta [/tex], the box will move upward parallel to the ramp. Therefore, the maximum [tex]F_{app}[/tex] if the box is to remain at rest:
[tex]F_{app} = F_{s} + F_{g} sin \theta[/tex]
[tex]F_{app} = \mu_{s} * m * g * cos \theta + m * g * sin \theta [/tex]
[tex]F_{app} = m * g ( \mu * cos \theta + sin \theta ) [/tex]
[tex]F_{app} = 22 kg * 9.8 \frac{m}{s^{2}} * (0.78 * cos 45 + sin 45) [/tex]
[tex]F_{app} = 270N[/tex] (correct to two significant digits).
Am I doing it correctly? I'm suspicious that I'd need to plug in the kinetic friction force somewhere.. Plus when I do some calculation, it seems that the downward force parallel to the ramp ([tex]F_{g} sin \theta[/tex]) is greater than the [tex]F_{s, max} = F_{N} * \mu_{s}[/tex] which means the object should be experiencing a downward acceleration parallel to the ramp. However, the question explicitly mentioned that the box is at rest. Is this caused by the kinetic friction force?
About question (b), I'm not sure how could a force perpendicular to the ramp affects the motion of an object on the ramp since the applied force is perpendicular to the possible direction of the boxes motion (down the slope or up the slope). And I don't know whether the motion will be upward or downward parallel to the ramp.
However, I have a partial solution. But I don't know how to insert my free body diagram to this post. If anyone could help me, I'd greatly appreciate that :smile:.
But basically I assumed that the net force will be going down parallel to the ramp since any object will naturally fall to ground. If the downward force parallel to the ramp > (Fs, max) the box will move from rest. As described: [tex]F_{down} > F_{s, max}[/tex]
So I need to calculate:
a) the downward force parallel to the ramp
b) the [tex]F_{s, max}[/tex] opposing the motion
I can find the force mentioned in (a) by considering that the resultant force perpendicular to the ramp can be calculated by adding the applied force to the component of gravity perpendicular to the ramp: [tex]F_{resultant} = F_{app} + F_{g} cos \theta[/tex].
From there, I could find [tex]F_{down} = F_{resultant} * tan \theta[/tex].
Since [tex]F_{resultant} = F_{app} + F_{g} cos \theta[/tex]. Through subsitution, if the object is to move from rest:
[tex]( F_{app} + F_{g} cos \theta ) * tan \theta > F_{s, max}[/tex]
Therefore, the minimum magnitude of Fapp is:
[tex]F_{app} = (F_{s, max} / tan \theta) - F_{g} cos \theta[/tex]
Is it correct?
Thanks very much!
your part a looks right to me
for part b, when you apply the perpindicular force, the normal force changes, correct? so then the friction force will also change.
So if the object is to stay at rest, I need to find the Fs where: [tex]F_{s} = F_{s, max}[/tex]. From there, I could find Fn through: [tex]F_{N} = F{s} * \mu_{s} [/tex]. Then I could find The Fapp since: [tex]F_{app} = F_{N} - F_{g} cos \theta[/tex]
Is that correct?
Also, does it mean kinetic friction force has no effect here?
yes, seems like it
Is that correct?
If the object is to stay at rest, you would need to find Fs where Fs = Fgsin theta.
ah that's correct. Thanks a lot andrew :)
What is the definition of ramp and friction?
Ramp refers to an inclined surface used to move objects from a lower to a higher level. Friction is the force that acts between two surfaces in contact and opposes the motion of an object.
How does the angle of the ramp affect the forces involved?
The steeper the angle of the ramp, the greater the force of gravity pulling the object down the ramp. This increases the amount of friction needed to prevent the object from sliding down too quickly.
What is the difference between kinetic and static friction?
Kinetic friction is the force that opposes the motion of an object as it moves across a surface. Static friction is the force that keeps an object at rest and resists any attempt to move it.
How can friction be reduced on a ramp?
Friction can be reduced on a ramp by using materials with smooth surfaces, applying a lubricant, or reducing the weight of the object being moved.
What are some real-life examples of using ramps and friction?
Ramps and friction are commonly used in everyday life, such as using a ramp to load heavy objects onto a truck or using friction to stop a car on a slippery road. They are also used in engineering and construction, for example, in building ramps for wheelchairs or incorporating friction into the design of machinery to prevent slipping or sliding.
14K
