Dynamics skydiver +drag force
In summary, a sky diver weighing 890N and falling vertically at 30.5m/s experiences a drag force of 0.5v^2. Upon opening his parachute, his acceleration can be calculated using the equation a=g(1-0.5v^2/W), which yields an answer of 24g if v=210.95m/s or W is smaller. However, there may be errors in the problem or conversion issues.
Melawrghk
145
A sky diver and his parachute weigh 890N. He is falling vertically at 30.5m/s when his parachute opens. With the parachute open, the magnitude of the drag force (in Newton) is 0.5v2.
What is the magnitude of the sky diver's acceleration at the moment the parachute opens?
F=ma
So I figured the drag force is acting up and =0.5v2, weight acts down and = 890N, the sky diver accelerates downwards at (W/g)a
So I got to an equation:
0.5v2-890=-(890/9.81)a
I just tried plugging in the velocity at which he's falling (because at the instant the parachute opens, the velocity doesn't change yet) and got a=4.89. But the answer is supposed to be 24g. I don't really get that, at all. Help?
First of all 24g sounds way off. The drag force will not be greater than that of gravity, and the acceleration due to gravity will be 1g. Therefore, your answer should be >0g, and <1g. 4.89 Sounds entirely reasonable. Below is how I would do it. A little different with the signs but will still yield the same answer.Begin with a free body diagram W-.5v^2=M*a
so something like [890-.5(30.5^2)]/(890/9.8)=a
a-=4.67
slightly different, however you reversed some negative signs I would recommend drawing a diagram and seeing what works best.
So you just picked the negative direction as positive, I guess. Also, I get 4.68, it's just that calculation I must have entered something wrong. Glad to hear it's not me being an idiot, but maybe the book being wrong. Thanks!
(24/9.81) * 2 = 4.89
Is that random number play or is there logic behind it you would like to explain?
Something doesn't make sense in this problem. The terminal velocity of a parachutist is something like 8m/s or so. If the skydiver is initially traveling 30.5m/s as he opens his chute, that's much greater than terminal velocity, such that the the initial net force must be up, and the acceleration initially must be directed up, at a rather large rate, thus slowing down his initial speed. Check the problem again for the drag equation: did you type it incorrectly?
No see the net force will NEVER be up in this situation. Unless there is an external force such as a gust of wind or a jet pack. We only have in this model 2 forces, force due to gravity, and air resistance. This resistance is dependent on the downward falling motion. Given what we are given I feel we can not make a truly concise answer. So here are some additional equations to think about.
F(drag)=-.5pv^2AC
In which C is the drag coefficent, p is density of air, v is velocity and A is the area of the cross section. (For the record let me clarify this can be a vector as all forces can)
V(terminal)=sqrt((2mg)/(pAC))
In our case we again do not know area or C but, 2mg we know to be 2*890. p somebody surely has memorized, so really we have no basis for this question. In cases of really small C and A we have very large V and very small F. Your example of what the terminal velocity is for parachutists although apt in some cases is not a constant. Therefore these numbers may or may not be completely correct. I am however very interested to see the final result.
F(drag)=-.5pv^2AC
The net force initially MUST be up if the diver is falling initially at a speed greater than the terminal speed of the parachute/diver system. If he jumped from rest with the chute open, then, yes, the net force must always be down. Such is not the case here. The diver, traveling at 30m/s initially, opens his chute, and he feels a sudden jolt from the upward acceleartion. He is still traveling down, but the acceleration, initially, is up. The problem statement has some errors in it, or it was copied down incorrectly. I did some quick math, and using the drag force equation, its more like F_drag = 15v^2, not .5v^2.
Jay, that's exactly how it appears in the problem, actually. I was able to rearrange the equation in a different way:
a=g(1-0.5v^2/W)
And from that, a would equal 24 g if v=210.95m/s, or W was smaller. There is a similar example in the book which yields 24g, but in that case units were american (v=100ft/s, W=200lb) which are basically the same numbers if you convert to metric. So I'm thinking maybe it's the drag force formula? I guess the book might not have been entirely converted to metric, or something. I don't know. Thanks for all the help!
Yes, it could be that the problem messed up the units. Using F_drag = 0.5v^2, we know that at terminal velocity, the drag force equals the weight. Setting 890 = 0.5(v_term)^2, that yields a terminal velocity of about 42m/s, which, in USA units, is about 100mph! You might as well just jump without the chute, the terminal velocity of a person jumping without a chute is about 120mph or so, depending on his position as he falls. That's one heck of a lousy chute; either way, its lights out when you hit the ground (unless you're lucky enough to fall in a field of marshmallows :wink:).
Checking the numbers again, you are exactly correct, there was a textbook error in the conversion: they forgot to adjust the drag formula accordingly. Using the units of v_o = 100ft/s, and W=200 lbs, and F_drag = .5v^2, then F_drag = 5000 lbs, F_net = 5000 - 200 = 4800 lbs up, and the instantaneous accelertaion is F_net/m = 4800(g)/200 = 24g's up. That's a big acceleration, but it doesn't last long; the speed rapidly reduces and the drag force reduces accordingly, such that in just a few seconds, terminal velocity is reached ('a' goes down to 0), v_term = 20ft/s, or about 15mph, equivalent to free fall jumping from a 7 foot high set of stairs.
1. What is a skydiver's terminal velocity?
A skydiver's terminal velocity is the maximum speed at which they can fall through the air due to the opposing force of drag. It is typically around 120 mph for a person in a belly-to-earth position.
2. How does drag force affect a skydiver's descent?
Drag force is a resistance force that acts in the opposite direction of a skydiver's motion, slowing them down as they fall. As a skydiver's speed increases, so does the force of drag, until it reaches a point of equilibrium with the force of gravity, resulting in a constant descent speed known as terminal velocity.
3. What factors can impact the amount of drag force experienced by a skydiver?
The amount of drag force experienced by a skydiver can be affected by several factors, including the shape and size of the skydiver's body, the density and viscosity of the air, the speed of the skydiver's descent, and the presence of any objects or obstacles in the surrounding environment.
4. How does the skydiver's body position impact the effect of drag force?
The skydiver's body position plays a crucial role in determining the amount of drag force they experience. A "spread eagle" position creates more surface area and therefore more drag, while a streamlined "pencil" position reduces drag and allows for a faster descent. The position can also affect the stability and control of the skydiver's descent.
5. Can a skydiver control their descent speed by manipulating their body position?
Yes, a skydiver can control their descent speed to some extent by changing their body position. By adjusting their arms, legs, and torso, a skydiver can increase or decrease their surface area and thus the amount of drag force experienced. However, a skydiver's ultimate terminal velocity will still be determined by the force of gravity and the density of the air.
  • General Math
10K
23K
