Dynamics- Two Body Problems
  • Archived
  • Thread starter hsphysics2
Two blocks are stack on each other. The lower block has a mass of 6.8kg and μs=0.34 with the floor. The top block has a mass of 3.4kg and μs=0.65 between the two blocks. A force of 18N is being applied to the top box to the left. What maximum force can be applied to the lower block without the upper block slipping? What is the acceleration of the system?
Fx= max
I drew free body diagrams for the system, and started the 3 equations as the following;
for mA,
Fx= mAax
T- μsη-mAgsinθ= mAax 1)
Fy= maay
η-magcosθ=0
for mB,
Fx= mBax
mBg-T=mBax 2)
I think I should add 1) and 2) to each other so I can get rid of T but I'm not sure about where I should go from here.
Answers and Replies
haruspex
Insights Author
2020 Award
36,974
7,209
Since the OP has chosen an unusual set of variable names and not defined them, I cannot comment on the equations given.
The first thing to check is the state of things with no force applied to the lower block. We find that the 18N is sufficient neither to make the top block slide on the lower block, nor to make both blocks slide on the table.
Next, we must ask what the force applied to the lower block must do in order to make the blocks slide relative to each other. If it also makes nothing move then the 18N still won't. So the extra force must make the lower block accelerate so fast that the combination of the top block's inertia and the 18N force overcomes the static friction.
|mAsA|<|FA+amA|, where the acceleration a is measured oppositely to the 18N force.
Note that this has two solutions.
To achieve this acceleration, a(mA+mB)=FB+/-(mA+mB)gμkB, where the +/- sign is opposite to the sign of FB.
Since we are not told any coefficients of kinetic friction, we cannot go further without making assumptions.
Related Threads on Dynamics- Two Body Problems
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
