Dyno Rooms
  • Thread starter Pen Repine
Hi The company I work for has a Dyno room for tuning its engines before sale.
Can someone advise me on an electronic noise retardant please?
The room where the Dyno is situated is quite small and doesn't really have the ability to be lined with a material unless it were less that 25mm thick.
Penn
Danger
244
Welcome to PF, Pen.
I don't know any details, but there are active noise-cancelling systems that invert the sound input and emit the opposite signal through speakers or transducers. In automotive terms, they're referred to as 'active mufflers'.
FredGarvin
I'd look at putting some kind of removable enclosure around the engine and then pump outside air in to help with combustion air and cooling. If you don't have any room to soundproof, there aren't really any other options.
Active noise cancellation does not work for broad band noise. It focuses on particular frequency contributions.
Danger
244
Thanks, Fred. I wasn't aware of the frequency restrictions of active cancellation.
Hi Guys,
Thankyou for your advice thus far.
Here is the heads up on what I have, the Dyno is a Dynojet rolling road style dyno.
It is in a room made from Bessa brick, and fire check plaster.
The outside noise is way over the top, mainly due to the fact that the engines are Harley-Davidsons.
The outside noise is quite important as the room is situated in the reception area of our new service centre.
I have a great air induction system pulling about 24 thou ltrs per sec.
The room size is approx: 4.4L x 2.1W X 2.5H.
The room is a great place to work as far as air is concerned have never felt the slightest taste of gas.
Welcome to PF, Pen.
Thanx Danger,
This is exactly what I am looking for.
I simply don't know enough about it to go and shop for such an item.
Pen
Danger
244
Unfortunately, as Fred pointed out, active cancellation might not be applicable in your situation. :frown:
What sort of exhaust ducting do you have? Most of the noise comes from the tailpipes, so maybe something can be done in that area (as long as changes of backpressure don't mess up your dyno readings too much).
Related Threads for: Dyno Rooms
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
25K
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
