Proton Beam Moving in +x Direction Through E and Magnetic Field
In summary: So the charges do not "cancel out" in the sense that they don't matter, but they do "cancel out" in the sense that they won't change the result.In summary, a beam of protons moving in the +x direction through a region where the electric field is perpendicular to the magnetic field will not be deflected. This is because the net force on the protons is zero, as indicated by Newton's First Law. The sum of the forces from the electric and magnetic fields is equal to zero, which is why the protons are not deflected. If the protons were replaced with electrons, they would also not be deflected because the forces from the two fields are proportional to the magnitude of the charge, so
charlies1902
162
A beam of protons is moving in the +x direction through a region where the e field is perpendicular to the magnetic field. The beam is not deflected.
For the part "the beam is not deflected," how do you know if it'll be deflected or not? Or will that usually be given? Also why does the force of the e field and the force of the magnetic field add up to = 0?
please help someone. thanks in advance
Please don't "bump" your thread before waiting 24 hours. That's one of the rules for these Forums.
How much do you know about the force that a magnetic field can exert on a charged particle?
How much do you know about the force that an electric field can exert on a charged particle?
I'm not sure if I understand what you're asking. can you clarify?
Sure, what part of my post wasn't clear?
1) Bumping?
2) what you know regarding mag. field?
3) what you know regarding E field?
The last 2 questions. I know the equations and how to use them, if that's what you're asking.
If they tell you that the electrons are not deflected, then the net force must be zero (Newton #1). That tells you something about the orientation and relative magnitudes of the fields. Otherwise, if they give you the field details it's up to you to determine the net result!
Does deflection basically mean the direction the proton is going is changed when it moves thru the field? So if it stays in the same motion that means sum of forces=0.
Also, the next question asks if the protons were replaced with electrons, would they be deflected? I don't know how to explain this. I just said when you sum up forces charge ends up cancelling out so the sign of the charge will not matter. Is that a legit justification?
Correct.
I think what you mean is that, since the forces involved are both proportional to the magnitude of the charge, if they cancel for one sign of charge they must cancel for the other.
gneill said:
Correct.
after I stated that I second guessed myself. Since the question asks if the e- will be deflected we can't assume that the force of the e field and the force of the magnetic field is equal to 0 right? If so, then I can't say the charges canceled out.
In order for the force of the individual fields to be zero there would have to be no fields.
In order for the sum of the forces due to the fields to be zero they must have a particular ratio of strengths and particular orientations with respect to the particle motion.
The charges do not cancel out if you are summing the forces. But they do affect the magnitude of the forces to the same degree. Write the equations for each force. Write their sum. Can you factor the charge out of the sum?
Uh, if I factor it out then wouldn't that means the charge does come into play? The only way I see them as not having an effect is if the 2 forces are set to 0, thus the charge is canceled.
Of course it comes into play! It's setting the magnitudes of both forces. But if both forces scale in the same way with the charge, then they will have the same ratio no matter what the charge, and will continue to cancel.
Write the equations for each. Write the expression for the sum of them. If you can factor q out of that expression so that it stands alone, i.e., F = q*(stuff - otherstuff), and if F=0, then either q is zero (and it's not!) or (stuff - otherstuff) is zero and will be zero for ANY charge q.
1. How does the proton beam move in the +x direction through E and a magnetic field?
The proton beam moves in a straight line through the +x direction due to its inertia. The electric field (E) and magnetic field (B) are perpendicular to each other, causing the proton beam to experience a force in the +x direction according to the right-hand rule.
2. What determines the direction of the force on the proton beam?
The direction of the force on the proton beam is determined by the relative orientation of the electric and magnetic fields. If the electric and magnetic fields are parallel, the force will be in the same direction as the proton beam's motion. If they are perpendicular, the force will be perpendicular to the proton beam's motion.
3. How strong is the force on the proton beam?
The strength of the force on the proton beam depends on the magnitude of the electric and magnetic fields, as well as the charge and velocity of the proton. The force can be calculated using the equation F = q(E + v x B), where q is the charge of the proton, E is the electric field, v is the velocity of the proton, and B is the magnetic field.
4. How does the proton beam's velocity affect its path through the electric and magnetic fields?
The velocity of the proton beam affects the magnitude of the force it experiences in the electric and magnetic fields. A higher velocity will result in a greater force, causing the proton beam to curve more as it passes through the fields. However, if the velocity is high enough, the proton beam may have enough inertia to continue moving in a straight line despite the force.
5. Can the path of the proton beam be controlled in this system?
Yes, the path of the proton beam can be controlled by adjusting the strength and orientation of the electric and magnetic fields. By changing the magnitude and direction of these fields, the force on the proton beam can be altered, causing it to follow a different path. This is the principle behind particle accelerators and other devices that use electric and magnetic fields to manipulate charged particles.
