E field in the X direction
  1. Nov 13, 2009 #1
    The electric potential along the x-axis is V = 50x - (100/x)V, where x is in meters. What is E_x at x = 1.0m
    2. Relevant equations
    partial derivative of dV/dx, then plug in the value for x
    3. The attempt at a solution
    I understand the concept of trying to solve the equation you have to take the partial derivative of the equation with respect to x, when I do that I get 1-100(x), which is were I think I am going wrong.
    Der 50x would just be 1
    Der 100/x =100x^-1 = -100x
    so when I put x=1 in for the equation and solve I do not get the right answer.
  3. Nov 13, 2009 #2
    Delphi51
    V = 50x - (100/x)
    = 50x -100*x^-1
    dv/dx = 50 - 100(-1)x^-2
  4. Nov 13, 2009 #3
    so when i solve for x=1 i get 150. I put that answer in and it still says its wrong but to check my signs.
    I changed it to -150 and its correct... am i missing something?
  5. Nov 13, 2009 #4
    nevermind its -dv/dx which would give the -150 answer thanks...
    Finished that problem and now i have to do another one involving an x and a y component. Obviously you have to break the thing down into x and y but again i'm struggling on the partial derivative part.
    350/(sqrt (x^2 + y^2))
  6. Nov 13, 2009 #5
    Delphi51
    I missed it, too. The formula is E = - dV/dx.
  7. Nov 13, 2009 #6
    so the problem is now I don't know how to partial derive the function.
    350/ ( (x^2 + y^2)^-.5)
  8. Nov 13, 2009 #7
    Delphi51
    Looks kind of odd - are you sure you have keyed in that expression correctly?
    The way it stands, it simplifies to
    f = 350*(x^2 + y^2)^0.5
    To differentiate that with respect to x, you would use
    u = x^2 + y^2 so f = 350*u^0.5
    and the chain rule: df/dx = df/du*du/dx
    In the details of that, you'll need the power rule a couple of times:
    d/dx of x^n = nx^(n-1)
    Give it a try!
  9. Nov 13, 2009 #8
    yea the equation 350/sqrt (x^2 +y^2) is given as what voltage equals and x and y are in meters. It then asks what the strength of the electric field is at x=2 and y = 2.7. I have to partially derive the equation. Once for x and once for y. Put the values in and solve for each component. I just can't get the derivation right.
  10. Nov 13, 2009 #9
    Delphi51
    First you gave 350/ ( (x^2 + y^2)^-.5)
    Then you gave 350/sqrt (x^2 +y^2)
    These are not the same. The square root of u is the same as u^0.5 with no minus sign.
    For V = 350/sqrt (x^2 +y^2) you would use the same idea
    Let u = (x^2 +y^2) so that V = 350/u^0.5 = 350*u^-0.5
    dV/dx = dV/du*du/dx
    Do have a go at it and show your work so we can advise you further!
  11. Nov 13, 2009 #10
    ok so dV/dx = dV/du * du/dx
    dV = .5*350u^-.5 = 175u^-.5
    du = 2x + 2y
    175u^-.5/2x+2y * 2x+2y/2
    =175u^-.5/2
    for the x partial derivative and
    175u^-.5/2 for the y partial
    doesn't look right
  12. Nov 13, 2009 #11
    Delphi51
    The derivative of y = x^n is dy/dx = n*x^(n-1).
    If you had y = x^3, then dy/dx would be 3*x^2.
    V = 350*u^-0.5 has an "n" value of -0.5 so
    dV/du = 350*(-0.5)*u^(-1.5)
    When differentiating u = x² + y², partially with respect to x, you take y to be a constant. So y² is also a constant and its derivative is zero.
    ∂u/∂x = 2x.
    It doesn't make sense to write du alone; derivatives are always a ratio of two infinitesimally small differentials like du/dx. Since we are doing partial derivatives, we really should write ∂u/∂x. You can copy symbols like that from
    https://www.physicsforums.com/blog.php?b=347 [Broken].
  13. Nov 13, 2009 #12
    that symbol thing helps;
    so
    dV/du = -175*u^(-1.5)
    now understanding that its a ∂u/∂x with respect to x; =2x and with respect to y; =2y
    but how to i complete the equation to get an equation
    -175*x^(1.5)/2x and -175*y^(1.5)/2y for the x and y directions respectively?
  14. Nov 13, 2009 #13
    Delphi51
    ∂V/∂x = ∂V/∂u*∂u/∂x
    = -175*u^(-1.5)*2x
  15. Nov 13, 2009 #14
    I am lost again...
    Do i just put the u value ( x^2 +y^2) back in the equation and solve for x and then do the same thing but with ∂u/∂y for y?
    my x and y values were 2.0 and 2.7 respectively.
  16. Nov 13, 2009 #15
    Delphi51
    u = x² + y² = 2² + 2.7² = 11.24
    ∂V/∂x = -175*u^(-1.5)*2x = -175*11.24^(-1.5)*2*2 = -18.5
  17. Nov 13, 2009 #16
    yea i'm not getting that answer to work for the Efield at point (2,2.7)
  18. Nov 13, 2009 #17
    Delphi51
    Oh, did you remember the minus sign in Ex = -∂V/∂x this time?
    Also, how are you combining Ex and Ey?
    "It then asks what the strength of the electric field is at x=2 and y = 2.7."
    suggests the answer is a single number for the E field, not separate Ex and Ey.
    If you lay out the whole calc here, I'm sure someone will check it out for you!
