E field
  1. Mar 8, 2012 #1
    What is the magnitude of the collective contribution to the E field at the origin from both the + and - charges located 5 cm above the horizontal axis?
    2. Relevant equations
    kQ/d^2
    3. The attempt at a solution
    Im just having a problem setting up this problem. Could someone help me on getting started
  3. Mar 8, 2012 #2
    tiny-tim
    hi sasuke07! :smile:
    (try using the X2 button just above the Reply box :wink:)
    first, find the magnitude of each contribution,
    from that, find the x and y components …
    what do you get? :smile:
  4. Mar 8, 2012 #3
    I already figured out the magnitued of the the positive charge 5 cm above the axis and got 5.4X10^4. What do you mean by the x and y components. WOuldn't the negative charge have the same magnitude of the positive charge.
  5. Mar 8, 2012 #4
    tiny-tim
    yes :smile:
    draw an arrow at the origin showing the direction of the field from the positive charge
    then find the x and y components of that arrow
    (and finally you'll add them to the x and y components of the arrow from the negative charge :wink:)
  6. Mar 8, 2012 #5
    so to figure out the x component wouldn't it be Kq/d^2 where k=9X10^9, q is 30X10^9= charge and d would be .05m^2. Or would i have to use cosine and sine to figure out the x and y components and if so could you show me how to set it up.
  7. Mar 8, 2012 #6
    tiny-tim
    no, you must use cos and sin, of the angle the arrow makes
  8. Mar 8, 2012 #7
    so would it be Kq/r^2sintheta
    and Kq/r^2Costheta. Where theta would be 90 degrees?
  9. Mar 8, 2012 #8
    or would theta be 45
  10. Mar 8, 2012 #9
    tiny-tim
    θ is the angle of the line from the charge to the origin
  11. Mar 8, 2012 #10
    awesome so 45 degrees.
  12. Mar 8, 2012 #11
    So were the equations correct though?
  13. Mar 8, 2012 #12
    tiny-tim
    looks ok :smile:
    so what is the total field from both the positive and the negative charge? ​
  14. Mar 8, 2012 #13
    i got 7.6X10^4 by doing KQ/r^2sin45 and the answer is the same for cos45. BUt i checked the answer and its supposed to be 7.1X10^4. Any suggestions
  15. Mar 8, 2012 #14
    tiny-tim
    your answer looks right to me :confused:
    (are you sure it's 5 cm that they're asking about?)
  16. Mar 8, 2012 #15
    i think its 5cm because the length of the x and y components is 5cm.
Similar Discussions: E field
  1. E- Field (Replies: 6)
  2. E field (Replies: 1)
  3. E-Field and Voltage" (Replies: 6)
Loading...
