Compound Interest & Number e Connection
In summary, the number e was first discovered in compound interest calculations and it is equal to (1+1/n)^n as n approaches infinity. The fact that e is its own derivative and integral is not a coincidence, as it is a direct consequence of its definition and the formula for compound interest. This was discovered by mathematicians such as Jakob Bernoulli and Euler, and it also relates to the derivative of other exponential functions.
Warp
128
Originally (as far as I know) the number e (ie. 2.71828...) came up in compound interest calculations.
For example, if you have 1 dollar, and a compound interest of 100% per year, and the interest is continuously calculated, after one year you'll have exactly e dollars.
The generic formula for this is (1+1/n)n, where n is the amount of times compound interest is calculated during the year. As n approaches infinity (which means it's continuously calculated), that formula approaches e.
Is the fact that ex is its own derivative just a coincidence, or is there a correlation with the above?
Mathematics news on Phys.org
The way we were first acquainted with the existence of ##e## was: We are looking for the derivative of ##f(x) = a^x##. From visual inspection there must be a real number ##a## such that this derivative is equal to 1 in ##(0,1)##.
That's not what I heard. But either way, it's not really what I asked...
You are right. I got carried away by memories ...:rolleyes:
You could investigate the Taylor series of your expression and see that it yields something looking suspiciously like ##f'= f##
[edit] that doesn't make much sense. Dug up a dog-eared yellowish textbook, copyright 1969 :smile:, on infinitesimals and found: we call this number ##e##.
So the derivative definition gives us ##\displaystyle f'(0) = \lim_{h\rightarrow 0}{e^h-1\over h} = 1## hence ##\displaystyle f'(x) = \lim_{h\rightarrow 0}{e^{x+h}-e^x\over h} = e^x \lim_{h\rightarrow 0}{e^h-1\over h}= e^x##.
Not interesting for you, but: a few pages further, on limits:
##f(x)=\log(1+x)\Rightarrow f'(x) = (1+x)^{-1} \Rightarrow \displaystyle f'(0) = \lim_{x\rightarrow 0}{\log(x+1)\over x} = 1## and now we do have an answer to your question !
Although e is now called Euler's number, it was actually discovered by Jakob Bernoulli (among other mathematicians) before Euler was born when he, Bernoulli, was investigating compound interest:
https://en.wikipedia.org/wiki/E_(mathematical_constant)
Euler's singular contribution was his formula which relates e, i, π, 0, and 1.
Considering the derivative of ## f(x)=e^{x}##:
##f'(x)= \lim_{h\rightarrow 0} \frac{e^{x+h}-e^{x}}{h}=\lim_{h\rightarrow 0}\frac{e^{h}-1}{h}\cdot e^{x},##
you can see that the derivative of ##e^{x}## differs from ##e^{x}## by the factor ##\lim_{h\rightarrow 0}\frac{e^{h}-1}{h}##. If we write:
## \lim_{h\rightarrow 0}\frac{\lim_{n\rightarrow +\infty}\left(1+\frac{1}{n}\right)^{nh}-1}{h},##
we can examine the sequence ##\frac{\left(1+\frac{1}{n}\right)^{nh}-1}{h}##. If ##h=1## then for ##n\rightarrow \infty## we have ##e-1## as limit, because it is a variation of the neper sequence you cited before. The fact that ##h\rightarrow 0## ''deforms'' the result of this sequence that under the limit for ##h\rightarrow 0## tends to ##1##. This permit to have the equality between ##f'## and ##f## ... this is the way how the growth of neper sequence is correlated with the derivative of the function ##e^{x}##.
There is a correlation - this is a direct consequence of the fact that e is its own integral.
Could you explain in vernacular how?
Did you read #4 or #6 ?
Or, rather, that ##\int e^x dx = e^x## plus an arbitrary constant.
1. What is compound interest?
Compound interest is the addition of interest to the principal amount of a loan or investment. It is calculated based on the initial principal and any accumulated interest from previous periods, resulting in a larger amount of interest earned over time.
2. How is compound interest different from simple interest?
Simple interest is calculated only on the initial principal amount, while compound interest takes into account the accumulated interest from previous periods. This means that compound interest will result in a larger amount of interest earned over time compared to simple interest.
3. What is the formula for calculating compound interest?
The formula for calculating compound interest is A = P(1 + r/n)^(nt), where A is the final amount, P is the principal, r is the annual interest rate, n is the number of compounding periods per year, and t is the number of years.
4. What is the connection between compound interest and the number e?
The number e, also known as Euler's number, is a mathematical constant that is closely related to compound interest. When the number of compounding periods per year approaches infinity, the formula for calculating compound interest becomes A = Pe^(rt), where e is the base of the natural logarithm. This demonstrates the connection between compound interest and the number e.
5. How can compound interest be used to grow investments?
Compound interest can be used to grow investments by reinvesting the interest earned in the initial investment, resulting in a larger amount of interest earned over time. This allows for exponential growth of the initial investment and can be a powerful tool for long-term investments.
10K
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
  • General Math
