E (with Ln)
  • Thread starter JPC
JPC
195
hey
i know what the log function is
log a (x) : can be translated to :
a ^ y = x
with y to find
but with the Ln its
ln(x) = e ^ y = x
with y to find
and e = about 2.7....
But why this number ?
whats special about 2.7.... ?
whats the exact value of e ?
arildno
Dearly Missed
9,948
130
The exact value of e is e.
Strategies to convert that value into its equivalent decimal representation abound, the most common centering on the defining identity of e:
[tex]e=\sum_{n=0}^{\infty}\frac{1}{n!}, 0!=1, n!=n*((n-1)!), n\geq{1}[/tex]
Goodmoring ALL,
the number e as "arildno" e=e and e can be calculated by an infinite series and it is a Real number.
But you asked why e?
we must know that e is the contraction of eulur, and was a mathematics scientist and he had make a great researches aboiut the number e.
also, what special about e?
physicains had found many phenomenans the changes by a function f(x) = log a(x) [log to the base a]
and the found that the aproximate value of a =2.7.....
360
Ever heard that [itex]ln[/itex] is sometimes called a natural logarithm.
Why would they call that natural and what a heck does [itex]e[/itex] have to do with nature you may ask.
Instead of answering this in a long and bit a philosophical way ,I will ask you quite a similar question :Why [itex]\pi[/itex] ,and why is important about that constant.I will not answer neither of two questions leaving you to ponder over them alone.
If you ask why is [itex]e=2.71...[/itex]and [itex]\pi=3.14...[/itex] than the answer is simple:That's becouse people like to use decimal number system (and I guess I know why ,when I take a look at my hands).
The last question "what's the exact value of e"?.The most difficult one.
Well I think I will not dare answering that one...
arildno
Dearly Missed
9,948
130
I've dared:
The exact value of e is e. :smile:
mathwonk
10,690
871
the exact value of e is: the smallest real number larger than all finite sums of the series:
1 + 1 + 1/2! + 1/3! + 1/4! + 1/5!+.............
it is also exactly the unique x value such that the area under the graPH OF Y = 1/X, FROM X=1 TO x=e IS 1.
it is also probably the unique smallest real number larger than all the powers of form (1+ 1/n)^n, for all positive integers n.
it is approximately equal to 2.718281828459......
e is the unique positive real number a such that the derivative of the function a^x is a^x.
e is the value at x = 1, of the unique solution of the equation
f' = f, f(0) = 1.
e is the unique positive real number a such that the function f(x) = a^x has derivative at zero equal to 1, i.e. such that f'(0) = 1.
I've dared:
Yes ,yes .Of course,that is an alphabetical number system !
How could I forget that one...:smile:
arildno
Dearly Missed
9,948
130
Two point seven, two times Ibsen, 459045...:smile:
D H
Staff Emeritus
Insights Author
15,329
681
Why e?
"Real and Complex Analysis" by Walter Rudin starts with a prologue on the exponential function. The first sentence is "The exponential function is the most important function in mathematics."
Among other very useful features,
  • The exponential function is the only function (to within a multiplicative constant) whose derivative is equal to itself.
  • The exponential function is related to the trigonometric functions via the Euler formula,[itex]\exp(ix) = \cos x + i\sin x[/itex].
  • The derivative of the inverse of the exponential function, [itex]\log x[/itex], is simply [itex]1/x[/itex].
53
The natural logarithm ln(x) is the simplest of the logarithms. It's defined as the area (or integral, if you will) under the graph y=1/t when t goes from 1 to x. Specifically, when the area is 1, ln(x)=e (just like mathwonk said). Also, the inverse function of ln(x) is e^x, which you may know is the only function which is its own derivative (well, it can be multiplied by a constant too), which makes it even more special.
arildno
Dearly Missed
9,948
130
Euler himself used "e" as signifying the exponential function.
Only fifth-rate mathematicians assign their own name to their objects of study, and Euler was top-of-the-notch.
Noone knows why he called the number "e"; it is perhaps most likely it originally was short-hand for "that number which serves most "naturally" as the base in Exponential functions".
HallsofIvy
41,682
864
Any exponential function ax has the property that its derivative (rate of change) is just a constant times itself: Cax. You can show that for a= 2, that number is less than 1 but that for a= 3 it is larger than 1. There exist a number between 2 and 3 such that the constant is exactly 1. That is the number we call e. The function ex has the property that its derivative is simply ex itself.
JPC
195
What does the : '!' mean ?
arildno
Dearly Missed
9,948
130
See post 2, for definition of n!
cristo
Staff Emeritus
72
"!" means factorial: 5!=5*4*3*2*1. So, in general n!=n(n-1)(n-2)...1.
JPC
195
thanks
i tested with a program :
with ent.text : sum of all from 0 to ent
res.tex : the result
Dim c As String
Dim d As String
Dim f As String
Dim a As String
f = "1"
a = "1"
c = 1
Do Until c * 1 = ent.Text * 1
a = a * 1 * c * 1
d = 1 / a * 1
f = f + d * 1
c = c + 1 * 1
Loop
res.Text = f
and result is good
Related Threads for: E (with Ln)
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
Hot Threads
