What Would Happen if Earth and a Black Hole Interacted?
In summary: The singularity is the "center" of the black hole, which we cannot say much about. There's 1/3 second of both disconfort and complete destruction, and then we don't know.
pchalla90
55
What would happen if the whole solar system were to be absorbed by a nearby black hole in an instant? would people on Earth realize anything different, because the relative distances between all the celestial bodies would remain constant because it was all absorbed at the same time?
black holes are dense enough to absorb light. so would the light coming from the sun cease to reach the earth? would gravity be the same between the organisms on the surface of the Earth and the earth? would the Earth still be going around the sun in the same manner?
this is just for fun. it's not schoolwork. just general curiosity.
Space news on Phys.org
Black holes produce enormous tidal forces as you get near to the event horizon. A tidal force is something that acts differently on different parts of a body, in the case of a black hole say you approached feet first, your feet would be accelerated towards the centre more rapidly than your head with unpleasant consequences! I think it was Steven Hawking who termed the phrase 'spaghettification' to describe this process!
So in a word, yes we would certainly notice if we were plunged into a black hole!
The good news is we would know the black hole was coming for years before it ate the solar system. The bad news is we would also know there is nothing we could do about it.
Not necessarily enormous: depending on the mass of the black hole, the tidal effects at the horizon may become lower than those found at Earth's surface.
Maybe not, and if we do notice, it won't be for long!
A rough calculation gives that about 1/3 of a second elapses between when discomfort is first felt and when the singularity is hit. This time is independent of the size of the black hole.
Quantification of this: If the mass of a black is greater than about 50,000 solar masses, then discomfort is first felt inside the horizon, not at the horizon or outside the horizon.
I haven't run the numbers for when tidal forces at the horizon equal tidal forces at the Earth's surface, but this happens for a black hole that has substantially more mass than 50,000 solar masses.
Does that 1/3 of a second mean the time between when we initially enter the black hole and when we feel the "spaghettification"? I'm assuming that's when you get stretched out to be taller than you should be (if you entered feet or head first). I'm also assuming it's like taking a picture of a human and simply extending it in one direction. Is it like that or am I completely off?
It's the time between it starts hurting (tidal acceleration exceeding 1G), and the time the singularity is hit. There is both stretching in the z direction, and crushing in the x and y directions.
Singularity? Is that when the body assumes its normal shape again? If that's true then there's 1/3 of a second of discomfort and then it's back to normal?
ah. what a pleasant ending.
thanks to all who replied.
I got around 50,000,000 solar masses to match a free fall tidal gradient on a human body at Earth's surface. This should allow for about 8 minutes of comfortable vacations inside the black hole.
1. What would happen to Earth if it got sucked into a black hole?
If Earth were to get sucked into a black hole, it would be stretched and compressed by the immense gravitational force. Eventually, it would be torn apart and become part of the black hole's singularity.
2. How close would a black hole have to be to Earth to cause damage?
A black hole would have to be relatively close to Earth, within a few light years, to cause any noticeable damage. However, even at that distance, the gravitational effects would still be significant.
3. Would Earth's orbit be affected if a black hole passed by it?
Yes, Earth's orbit would be affected by the gravitational pull of a passing black hole. The closer the black hole, the greater the effect on Earth's orbit.
4. Can a black hole destroy the entire Earth?
It is highly unlikely that a black hole could completely destroy the entire Earth. The size and distance of the Earth from a black hole would determine the extent of the damage. However, a black hole could potentially cause catastrophic damage to our planet.
5. Is there any way to protect Earth from a black hole?
Currently, there is no known way to protect Earth from the effects of a black hole. The gravitational pull of a black hole is so immense that it would be nearly impossible to resist or escape. However, the likelihood of Earth encountering a black hole in our lifetime is extremely low.
  • Cosmology
