Understanding the Earth-Moon Center of Mass and Its Effects on Lunar Orbit
In summary: This will give you a lot more information on the Moon's gravitational field.In summary, the center of mass between the Earth and the moon follows an elliptical path around the sun, but it is very close to an ellipse because this perturbing influence is very small.
dimensionless
462
Does the center of mass between the Earth and the moon follow an elliptical path around the sun? Does it wobble a little bit?
Astronomy news on Phys.org
The exact path of the center-of-mass of the Earth-moon system is very slightly perturbed from an ellipse by the gravitational attraction of the other planets. However, it is very close to an ellipse because this perturbing influence is very small.
Wouldnt the CoM between Earth and Moon wobble each month (or moon cycle) as it follows the elliptical path caused by the moon revolving once around the earth??
I know that the center of mass would be constant if they were both just orbiting each other.
Could the sun perturb this?
No, because the Earth is also orbiting about the Earth-Moon CoM.
Sorry to butt in with my own question, but can you explain this? (Not the actual tides part, but how it causes only one side of the moon to face earth. I always thought this was just a fluke, that the moon revolves once on its own axis for every one rev around the earth. Thinking about it, that would have to be one precise fluke!):bugeye:
Have you ever heard the term the 'far-side' of the Moon? Because of the effect on the Moon of tidal forces due to the Earth, the same side of the moon always faces the Earth. The rotation period and the orbital period of the Moon are the same. Therefore, Earth-bound observers can never see the 'far-side' of the Moon. Tidal forces cause many of the moons of our solar system to have this type of orbit.
I would guess that the CoG of the moon is off center, closer to the Earth/Moon CoG due to the bulging effect of the Earth on the moon.
http://www.windows.ucar.edu/tour/link=/the_universe/uts/moon1.html&edu=high
Is there any good net sources for general learning on this stuff you would suggest?
Homer Simpson said:
Sorry to butt in with my own question, but can you explain this? ... I would guess that the CoG of the moon is off center, closer to the Earth/Moon CoG due to the bulging effect of the Earth on the moon.
While the Moon does have some rather high non-spherical mass concentrations, it is primarily the second zonal harmonic (the "J2" term) that leads to the Moon's tidally-locked revolution. The second zonal harmonic by itself does not result in an off-center center of mass.
Google "gravity gradient torque".
1. What is the Earth-Moon center of mass?
The Earth-Moon center of mass is the point at which the combined mass of the Earth and Moon is evenly distributed. It is the average position of the two objects, and it is located approximately 4671 kilometers from the center of the Earth and 73 kilometers from the center of the Moon.
2. Why is the Earth-Moon center of mass important?
The Earth-Moon center of mass is important because it helps us understand the dynamics of the Earth-Moon system. It also plays a role in determining the orbit of the Moon around the Earth and the effects of tides on Earth's surface.
3. How is the Earth-Moon center of mass calculated?
The Earth-Moon center of mass is calculated using a mathematical formula that takes into account the masses and distances of the Earth and Moon. The formula is: x = (m1 * d1 + m2 * d2) / (m1 + m2), where x is the distance from the Earth's center, m1 and m2 are the masses of the Earth and Moon, and d1 and d2 are the distances from the Earth's center and the Moon's center, respectively.
4. Does the Earth-Moon center of mass change over time?
Yes, the Earth-Moon center of mass does change over time. This is because the Earth and Moon are constantly moving and exerting gravitational forces on each other. However, the changes are small and do not significantly affect the overall position of the center of mass.
5. How does the Earth-Moon center of mass affect the tides on Earth?
The Earth-Moon center of mass plays a key role in causing tides on Earth. As the Moon orbits around the Earth, it creates a bulge in the Earth's oceans on the side closest to the Moon, and a second bulge on the opposite side. This is due to the gravitational pull of the Moon on the Earth's surface. The position of the Earth-Moon center of mass also affects the strength of the tides, with a closer center of mass resulting in higher tides.
  • Astronomy and Astrophysics
