Earth waves
  1. Oct 24, 2009 #1
    Two points A and B on the surface of the Earth are at the
    same longitude and 60.0° apart in latitude. Suppose that an
    earthquake at point A creates a P wave that reaches point B
    by traveling straight through the body of the Earth at a constant
    speed of 7.80 km/s. The earthquake also radiates a
    Rayleigh wave, which travels across the surface of the Earth in
    an analogous way to a surface wave on water, at 4.50 km/s.
    What is the time difference between the arrivals of the
    two waves at B? Take the radius of the Earth to be 6370 km.
    I have the solution for this but I'm confused as to how to find the distance and the speed in this case. Can someone explain to me step by step as to why he distance is said to be like 2Rsin(30)?
  3. Oct 24, 2009 #2
    Delphi51
  4. Oct 24, 2009 #3
    what if they were 25 degrees apart woud i then use 25/2?
  5. Oct 24, 2009 #4
    Delphi51
    You should draw the diagram and see for yourself! If you have any difficulty with a problem, draw a diagram - it will help you organize the problem, your thoughts, and help you deduce a solution. Yes, when you split any angle in half like that you create a pair of right triangles so you can use the 2*sin(A/2) trick.
  6. Oct 24, 2009 #5
    ok so i tried 2(6.37e6)sin(25/2) which gets 2.76e6
    I know from that you want to obtain the the time with given velocities. so for my values i have v1=6000m/s and v2-4400m/s
    i divide 2.76e6 m/ 6000m/s to get 459.6s and with the other one 626.69s
    i subtract the values and i end up with 167.09, however that's incorrect. can you check my work?
    its hard for me to visualize it since its using terms like latitude and longitude so i can't really draw where what is.
  7. Oct 24, 2009 #6
    Delphi51
    A bit confusing since you haven't stated the actual question with the 25 degrees. For the surface wave I get
    distance = 25/360*2*pi*r = 2779 km
    time = 2779/4.400 = 632 seconds.
  8. Oct 25, 2009 #7
    same longitude and 25.0° apart in latitude. Suppose that an
    speed of 6 km/s. The earthquake also radiates a
    an analogous way to a surface wave on water, at 4.40 km/s.
Similar Discussions: Earth waves
  1. Wave ? (Replies: 3)
  2. Waves (Replies: 2)
  3. Earth's Shape (Replies: 7)
  4. Density of earth (Replies: 5)
Loading...
