Easy Calculation: How to Solve sqrt(x)*sqrt(4-x^2)=sqrt*(4x-x ^3)
  • Thread starter nothing123
  • Tags
    Calculation
In summary, the equation is sqrt(x)*sqrt(4-x^2)=sqrt*(4x-x^3), with x as the variable. The square root symbol (√) indicates that we are trying to find the value of x that, when squared, equals the number inside the symbol. To solve this equation, we can square both sides and use standard algebraic techniques. There are restrictions on the values of x, as it must be greater than or equal to 0 and not make the denominator of the square root equal to 0.
nothing123
97
How does sqrt(x)*sqrt(4-x^2) equal sqrt*(4x-x ^3)?
Thanks.
[tex]\sqrt{a}\sqrt{b} = \sqrt{ab}[/tex]
I would like to clarify that the provided equation is not entirely accurate. The correct equation should be sqrt(x)*sqrt(4-x^2)=sqrt(4x-x^3).
Now, to answer the question, this equation can be solved by using basic algebraic principles. We can first simplify the left side of the equation by using the property of square roots, which states that the square root of a product is equal to the product of square roots. Therefore, sqrt(x)*sqrt(4-x^2) can be simplified to sqrt(x*(4-x^2)).
Next, we can use the distributive property to expand the right side of the equation, which gives us sqrt(4x-x^3)=sqrt(4x-x^2*x).
Now, we can see that both sides have a common term of sqrt(4x), so we can simplify the equation by dividing both sides by sqrt(4x). This results in x=sqrt(4-x^2)=sqrt(4-x^2).
Hence, we can conclude that sqrt(x)*sqrt(4-x^2) is equal to sqrt(4x-x^3) and the equation is solved. It is important to note that when solving equations, we must follow the rules of algebra and be careful with the manipulation of equations to ensure accurate results.
1. What is the equation for "Easy Calculation: How to Solve sqrt(x)*sqrt(4-x^2)=sqrt*(4x-x^3)"?
The equation is sqrt(x)*sqrt(4-x^2)=sqrt*(4x-x ^3).
2. What is the variable in this equation?
The variable is x.
3. What is the purpose of the square root symbol in this equation?
The square root symbol (√) indicates that we are trying to find the value of x that, when squared, equals the number inside the symbol. In this equation, we are trying to find the value of x that satisfies the equation when both sides are squared.
4. How do you solve this equation?
To solve this equation, we can square both sides to eliminate the square root symbols. This will give us a new equation of x*(4-x^2)=4x-x^3. Then, we can simplify this equation and solve for x using standard algebraic techniques.
5. Are there any restrictions on the values of x for this equation?
Yes, there are restrictions on the values of x. Since we cannot have a negative number inside a square root, x must be greater than or equal to 0. Additionally, if we solve the equation and get a value of x that makes the denominator of the square root equal to 0, that value of x is also not valid.
