Easy derivative question
Poster has been reminded to show more work when posting schoolwork questions
derive this function
f(x) = (2x + x^3) / sqrt(x)
how can i derive this without using quotient rule? my prof is asking to do so without using it.
I
Answers and Replies
Geofleur
176
Can you rewrite it in a way that would allow you to use the product rule?
SammyS
Staff Emeritus
1,045
I
Write ##\ \sqrt{x} \ ## as ##\displaystyle \ x^{1/2} \ ## .
By the way, the word in English is differentiate, not derive.
Can this be done without product / quotient rule?
Just to remind myself of how quotient rule works...
I got to this point after using quotient rule:
((2x + 7x^3) / (2(x^1/2))) / x
How do i simplify this? Sorry I don't know how to use latex code.
Geofleur
176
OK, here's a hint for how to do it without the product rule either: ##x^m / x^n = x^{(m-n)} ##.
Okay using that I got something like x^5/2 + x^1/2. It doesn't seem correct, how would i account for the binomial on the numerator? would I write another expression for x such as x^h?
edit: I just misunderstood the question... I am allowed to use both the quotient and product rule.
7,152
It's not correct, but you're not too far off. And you should end up with two terms, so I don't understand what you're asking about accounting for the binomial.
What do you get if you carry out the division below?
alright... I got it.
I simply just subtract the exponents from the numerator and denominator so it became (2 + 5x^2) / 2x^1/2
7,152
No, that's not even close. There's some very basic algebra that you need to review. If you don't, you absolutely won't be able to do calculus.
##\frac{(a + b)} c = (a + b) \cdot \frac 1 c = a \cdot \frac 1 c + b \cdot \frac 1 c## . Use the distributive property to multiply each term of a + b by 1/c. Can you apply this idea to your problem, ##\frac{2x + x^3}{\sqrt{x}}##?
Related Threads on Easy derivative question
  • Last Post
  • Last Post
10K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
