Carbon Dating and Half-Life: Calculating the Age of Ancient Objects
In summary: So, in summary, the process of carbon dating compares the amount of carbon-14 present in an item to the amount that would be present if the item were created in the present. The half-life of carbon-14 is approximately 6000 years, meaning that after each half-life, half of the original amount of carbon-14 will remain. To determine the amount of carbon-14 remaining after n half-lives, the equation is y = Ce^{kt}, where n is the number of half-lives and k is positive or negative depending on growth or decay. To calculate the number of half-lives, divide the total time by the time for 1 half-life. For part a, the equation would
joejo
150
hey can someone help me out with this question...I have an test 2mr on this time and don't have any more time to waste. So can someone please show me how to do it...so I can study of it...thanks in advance
Scientist are able to determine the age of very old, naturally occurring items through the process of carbon dating. Carbon dating compares the amount of carbon-14 (C-14) that is present in an item with the amount that would be present if the item were created in the present. The half-life of C-14 is approxiamtely 6000 years.
a) Suppose that a piece of wood is cut from a tree. The piece of wood contains 32g of C-14. Write an equation to determine the amount of C-14 remaining after n half-lives.
b) Determine the amount of C-14 that would remain after 12000 years.
c) Suppose that scientists in the future carefully examine the piece of woor and determine that it contains 2g of C-14. How far in the future has the wood survived? Explain your solution.
The basic form of exponential growth/decay, is
[tex]y = Ce^{kt}[/tex] .
k is positive or negative depending on if there is growth or decay. Start from there.
Each half life, there is half of the amount of what there was before of the substance experiencing the half life (in this case carbon 14).
Originally there was 32 grams, after 1 half life (6000 years), 16 grams, then another 600 year later, 8 grams left, ...
This process works like exponential decay,
original amount * .5^n, where n is the number of half-lives it has had.
to find out the number of half-lives it has experienced, simply divide the total time by the time for 1 half life,
12000 years over 6000 year = number of half lives
for the last question it it a bit trickier, it involve logorithms, but is not too hard if you remember the formula of how to detemine how much of a substance is left,
32 grams * .5^n = 2 grams
divide both sides by 32 to get,
.5^n = 1/16
then solve for n,
log(.5^n) = log(1/16), which =,
n*log(.5) = log(1/16)
divide both sides by log(.5) to get n,
then check the answer to make sure it it right.
we haven't done logs...this is suppose to be a remedial math...I'm looking for someone to answer it properly so I use this question to study from...Can someone please help me out...
You don't need logs to do part c. Just count how many times you need to divide 32g in half to end up with 2g--that will tell you the number of half-lives that must have passed.
im lost...can someone show me how to do it...i need to study of this now...
a) general form [itex]a \cdot b^n[/itex], so [itex]32(\frac{1}{2})^{\frac{n}{6000}}[/itex] - "n" is years in this problem
b) substitute for n
c) trial and error without logs :smile:
still lost...i don't get it...im trying to do this correspondance and its very difficult
Lets start with what a half-life is- how long it takes until a substance has lost half its mass.
Therefore, in one half life (in this case 6000 years), half of the mass of the substance will be ‘lost.’ Thus, after 6000 years, only 16g (32/2) will remain.
In another 6000 years (after 2 half-lives), half of this amount will be ‘lost’ leaving 8g (16/2) of the substance.
After the 3rd half-life, half this will be ‘lost’ leaving 4g. And so on.
You should be able to calculate the equation from here for part a.
For part b, 12000 years is equal to 2 half lives. You can use your equation from part a to calculate how much is left after 2 half lives.
For c, what value of n in your initial equation gives the value 2g? Each half life is equal to 6000 years so you can convert ‘half-lives’ to years.
so what would the equation be?
I'm not sure in this forum that we can just give you the equation but you should be able to work it out form the information given. This table should make it clearer.
Number of half-lives
Mass of Carbon-14 (g)​
32 (32/1)​
16 (32/2)​
8 (32/4)​
4 (32/8)​
2 (32/16)​
1 (32/32)​
etc
etc​
Note that to find the mass of carbon, the 32 is divided by roots of 2 (as shown). This should be reflected in your equation.
Show your working towards finding the equation and we can see where you are stuck/have gone wrong.
is that it?
Is that what? Your problem had 3 parts to it. Which one does that answer? And we won't be able to tell you if it answers anyone of those until you tells us what n means!
hallsofIvy you never seem to help people out...
anyways...n is the number of half-lives it has had...is that right Doc G or anyone else that is willing to help...
You're wrong. HallsofIvy always helps people out, and he's trying to get you to learn something instead of spoon-feeding you the answer.
"n" in multiples of 6000 would equal the number of half-lives gone by in the equation you posted, so what does that tell you about what n represents?
the number of half lives...my test is 2mr...can someone please answer it...its almost 2am and i don't get half life questions
All I can do is repeat what people have already told you:
"half" life means exactly that- the time required for the amount to halve. To find the amount remaining after n half-lives, you multiply by 1/2 n times.
The equation is just 32(1/2)n.
You are told that the half-life of C-14 is about 6000 years. 12000 is two half-lives.
Multiply by 1/2 twice (0r 32(1/2)2)
The piece of wood starts with 32 g and eventually has only 2 g. It has 2/32= 1/16= (1/2)4 as much as originally. That means 32 is multiplied by 1/2 4 times. How many half-lives is that? How many years?
thanks hall of ivy...as for that below...
there are 4 half lives...making it 8 years correct?
The piece of wood starts with 32 g and eventually has only 2 g. It has 2/32= 1/16= (1/2)4 as much as originally. That means 32 is multiplied by 1/2 4 times. How many half-lives is that? How many years?[/QUOTE]
No. How long is one half-life?
375 years...my test is in 5 hours...can someone please just check my answer and if its wrong state the correct answer...i've been up all night...thanks
Quoting the problem statement in your first post:
therefore the answer to c) is 375 years.
How did you arrive at that answer?
my test is in a few hours...if your planning on helping me out stop confusing me...you could help by telling me what the answer. thanks
If asking how you got your answer confuses you, there's not much I can do.
Try this for problem c. Answer each question in turn:
1) How many half-lives did it take to get from 32g to 2g?
2) How long is each half-life? (that's given)
3) What total time must have passed? (multiply!)
1) 16 half lives...
2) 6000 years
3)96 000 years..
is that right
joejo said:
1) 16 half lives...
That part's incorrect. You've already answered this before! See posts 17 & 18.
4 half lives...is the rest right?
or is it 24000 years now... because 6000*4
That is correct: 4 half-lives equals 4*6000 yrs = 24,000 yrs.
  • #31
FINALLY! YAY
thanks alot! :)
What is carbon dating and how does it work?
Carbon dating is a method used to determine the age of organic materials by measuring the amount of carbon-14 present in the sample. This is possible because carbon-14 is a radioactive isotope with a half-life of 5,730 years. As the organism dies, it stops taking in new carbon-14, and the existing carbon-14 begins to decay at a predictable rate. By measuring the ratio of carbon-14 to carbon-12 in a sample, scientists can calculate the approximate age of the object.
What is half-life and how is it related to carbon dating?
Half-life is the time it takes for half of the atoms in a radioactive substance to decay. In the case of carbon-14, it takes 5,730 years for half of the atoms to decay. This means that after 5,730 years, half of the original amount of carbon-14 will remain in the sample. By measuring the amount of carbon-14 remaining, scientists can determine the number of half-lives that have passed and calculate the age of the sample.
How accurate is carbon dating?
Carbon dating is generally accurate within a range of a few hundred years to a few thousand years. However, the accuracy can be affected by a number of factors, such as contamination, changes in the Earth's magnetic field, and the presence of other isotopes of carbon. Scientists also use other dating methods, such as tree-ring dating and uranium-lead dating, to verify and refine the results obtained from carbon dating.
What types of objects can be dated using carbon dating?
Carbon dating is most commonly used to date organic materials such as bones, shells, and wood. It can also be used to date fossils and artifacts made from organic materials. However, it is not suitable for dating rocks or inorganic materials, as they do not contain carbon.
What are the limitations of carbon dating?
Carbon dating can only be used to determine the age of objects that were once living and contain carbon. It is also limited to objects that are less than 50,000 years old, as the amount of carbon-14 remaining in the sample becomes too small to accurately measure after this time. Additionally, the accuracy of carbon dating decreases as the age of the object increases, and it is not useful for dating objects that are younger than 100 years old.
9K
  • Atomic and Condensed Matter
