Easy Math question
Find the points where each of the following lines intersects the x and y axes,
x=6,y=1+6t
for some reason I don't know how to find the point. If I graph it I understand but I can't work it out.
Answers and Replies
When you have x = 6, the x-intercept is automatically 6, because x = 6 is just a vertical line, so when y is 0, x must be 6. There is no y-intercept because the line never crosses the y-axis, this is because x cannot = 0.
What is the t supposed to be in y = 1+6t? A constant (number)? If 't' is a constant then you basically use the same idea.
Ok I get everything from the beginning, and I know I'm retarded I should have understood that. What is making me confused is the y=1+6t part.
that comes from the vector equation r=(6,1)+t(0,6)
Why do you even need to know the y=1+6t part? How do you check from that? I originaly thought you needed to set x or y to zero.....
BTW thanks
ok I completely Understand it now....But your explanation aswell as mine is purely based on Logical reasoning. Don't you have to set y=0 to find an x intercept?
HallsofIvy
41,833
956
Your original post: "Find the points where each of the following lines intersects the x and y axes" implies two different lines. Later you told us this was from r=(6,1)+t(0,6) which is a single line!
r= (6,1)+ t(0, 6) is the same as the parametric equations x= 6, y= 1+ 6t.
Since x is always 6, that line does not cross the y-axis. Of course, it crosses the x-axis at (6, 0).
In general, if you have parametric equations x= a+ bt, y= c+ dt, you find the x-intersept by setting y= 0, solve for t and use that value of t to find x. To find the y-intersept do the opposite: set x= 0, solve that equation for t and use that value of t to find y.
i just want to say. HallsoftIvy is a very patient and active tutor.
good work!
HallsofIvy
41,833
956
Who only screams and tears his hair occaisionally.
The real problem with the internet is that you can't use the two-by-four across the head and shoulders method!
Related Threads on Easy Math question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
