Easy number theory problem
  • Thread starter chimath35
An integer is divisible by 9 if and only if the sum of its digits is divisible by 9
Proof by induction?
Answers and Replies
I am new to proofs never done them, I am stuck ac=b 9c=b ex. 9c=81 so c is an int. thus divisible let b= d+dn so 9c=d+dn then 9c=d+dn+dn+9
hilbert2
Insights Author
551
In the decimal system, an integer with ##n## digits is written in the form
##\sum_{k=0}^{n-1}a_{k}10^{k}##, where the numbers ##a_{k}## are the digits.
Now consider the number
##\sum_{k=0}^{n-1}a_{k}10^{k}-\sum_{k=0}^{n-1}a_{k}##,
and deduce that it must always be divisible by 9. Then use the fact that if a sum of two integers, ##m+n## is divisible by 9 then either both ##m## and ##n## are divisible by 9 or neither of them is. That way you can prove the theorem.
Curious3141
2,850
87
Proof by induction?
Have you worked with modulo notation? Easiest way is to reduce the decimal representation ##\sum_{k=0}^{n-1}a_{k}10^{k} \pmod{9}## where the digits ##0 \leq a_k \leq 9## and make the observation that ##10 \equiv 1 \pmod{9}##. The rest should quickly follow, but if you get stuck, post back.
This is a great hint. Using this method, you can actually prove a stronger statement:
## a \equiv (\sum a_k) \ (\text{mod } 9) ##
where ##a_k## are the digits of ##a##.
Related Threads on Easy number theory problem
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
