Coordinate system for specifying the precise location of objects in space?
In summary, a coordinate system for specifying the precise location of objects in space is a frame of reference. A diagram is just a picture and the x and y-axis are components of a frame of reference that can be used to help solve a problem.
princesspriya
90
which of the following is a coordinate system for specifying the precise location of objects in space?
a. frame of reference
b. diagram
c. x-axis
d. y-axis
I thought it would be a diagram since it would use vectors and the x and y-axis to help solve a problem but i got it wrong. so can any1 please explain?
A frame of reference is a perspective from which something is observed. By defining your reference frame, are are defining your perspective (coordinate system).
A diagram is just a picture. What you thought a diagram was when you said: "a diagram since it would use vectors and the x and y-axis to help solve a problem". A diagram is just a picture, when you start to use vectors and axes, you just added a frame of reference to the diagram.
x-axis: According to what? Where is the axis?
y-axis: Same logic as above^^
oo i get itt thx
1. What is a coordinate system?
A coordinate system is a mathematical framework used to specify the precise location of objects in space. It uses a set of numbers or coordinates to define the position of a point or object in relation to a reference point or origin.
2. Why do we need a coordinate system?
We need a coordinate system to accurately describe the location of objects in space, especially in fields such as astronomy, geography, and navigation. It allows us to easily locate and track objects, and to make precise measurements and calculations.
3. What are the different types of coordinate systems?
There are several types of coordinate systems used in different fields, but the most commonly used are Cartesian coordinates, polar coordinates, and geographical coordinates. Each type has its own set of rules and equations for defining the position of an object.
4. How does a coordinate system work?
A coordinate system works by using a set of axes or reference lines to determine the position of an object. The axes are usually labeled with numbers or coordinates, and the position of an object is defined by its distance and direction from the origin or reference point.
5. Can a coordinate system be used to locate objects in three-dimensional space?
Yes, a coordinate system can be used to locate objects in three-dimensional space by adding a third axis, usually labeled as Z, in addition to the traditional X and Y axes. This allows for a more precise representation of an object's position in space.
