Easy Question about Fluid Statics
In summary, the textbook says that the forces on the base of the three containers are identical, but the pressure and area on the bottom of container 3 are different.
secret2
37
I am a newbie to fluid mechanics, and I am confused about the "hydrostatic paradox". To begin with, consider three containers. All three have the same base area (all circular), but the angle between the base and the "wall" are all different:
Container 1: obtuse angle
Container 2: right angle
Container 3: acute angle
And the textbook says that the FORCES on the base of the three containers are identical. Why should container 3 have the same as the rest?
Yes, the forces will be the same, provided the additional condition that the heights of the fluids are equal. Then, since pressures and areas are equal at the bottom, the same forces will apply.
Unfortunately, the link that minger provided does not illustrate the 3rd case, which is the most interesting one. In cases 1 and 2, there is an unobstructed column of fluid directly above the base, so it's easy to imagine that the force exerted on the base equals the weight of that column. But in case 3, some of the column of water is obstructed by the sides of the container; it turns out that the sides of the container exert a downward force that just compensates for the truncated height of the column of fluid. The net result is that the force exerted on the base is equal in all three cases (as long as the height of the fluid is the same).
Thanks a lot Doc Al! That's exactly my concern! But why would a force be exerted by the wall anyway?
Just one more scenario. Imagine that we have the following device:
Code:
[FONT=System]
|     |        /__       __\           \    /
|     |_______|      |________|  |_______
|__________________________________|
[/font]
Does the column in the middle have enough pressure (or force) to balance the others so that all three keep up the same level? If so, is it because for the column in the middle, once again, a force is exerted by the wall?
Thank you!
edited by enigma to add [ code ] and [ font ]tags for clarity
No good, the diagram doesn't come out right...I'll try describing it in words. The middle one has a circular base area, all of which is connected to the base. And the wall of the middle column, of course, makes an acute angle with the base.
Because the fluid pushes against the wall and the wall pushes back.
The fluid reaches the same height in all three columns.
The wall will exert a downward force on the fluid.
A couple of suggestions - if you wrap your ascii diagram in
[tex]\mbox{
Code:
}[/tex]
tags, it won't get reformatted.
The way I'd approach pressure is to look at a small volume element of fluid. The net force on the box will be the gradient of the pressure. But this approach may be a bit advanced, it's not the simplest possible approach.
http://astron.berkeley.edu/~jrg/ay202/node6.html
outlines this approach, having some nice diagrams.
The math requires vector calculus, but the link derives the fact that for any fluid in equilibrium in a conservative force field Phi (such that the force is the gradient of the potential - the Earth's gravitational field is an example of such a field, where the force is the gradient of -GM/R), surfaces of constant pressure, constant density, and constant potential Phi must all coincide.
1. What is fluid statics?
Fluid statics is the study of fluids (liquids and gases) at rest. It focuses on the behavior of fluids when they are not in motion, or when they are in a state of equilibrium.
2. What are some real-life applications of fluid statics?
Fluid statics is used in various fields such as engineering, meteorology, and biology. Some examples include designing dams and reservoirs, predicting weather patterns, and understanding the flow of blood in the human body.
3. How does the density of a fluid affect its behavior in fluid statics?
The density of a fluid plays a crucial role in determining its behavior in fluid statics. A fluid with a higher density will exert more pressure at a given depth compared to a fluid with a lower density. This is because the weight of the fluid is directly proportional to its density.
4. Can you explain the concept of buoyancy in fluid statics?
Buoyancy is the upward force exerted by a fluid on an object immersed in it. This force is equal to the weight of the fluid that the object displaces. This is why objects with a lower density than the fluid they are in float, while objects with a higher density sink.
5. What is Pascal's law and how does it relate to fluid statics?
Pascal's law states that pressure applied to a confined fluid is transmitted equally in all directions. This means that if you apply pressure to a fluid in a closed container, the pressure will be the same at all points within the fluid. This is a fundamental principle in fluid statics and is used in various applications such as hydraulic systems.
  • Materials and Chemical Engineering
  • Other Physics Topics
  • Science and Math Textbooks
  • Biology and Medical
  • General Engineering
