Calculating Force Exerted on 17-kg Box from 90-N Force Acting on 11-kg Box
  • Thread starter apples
  • Tags
    Confusing
In summary, when a 90-N force is applied to an 11-kg box on a frictionless surface, the resulting acceleration for both boxes is 3.2 m/s^2. The force exerted by the 11-kg box on the 17-kg box is equal to 55 N, while the force exerted by the 17-kg box on the 11-kg box is equal to 55 N as well, in accordance with Newton's third law. This can be determined by setting up a free body force diagram for both boxes. The final answer for the force exerted by the 11-kg box on the 17-kg box should be 55 N, rather than 35
apples
171
Two boxes are sitting side on a frictionless surface. The box on the left has a mass of 11kg and the box on the right has a mass of 17kg. If a 90-N force pushes on the 11-kg box from the left, what is the force exerted on the 17-kg by the 11-kg box?
A) 55 N
B) 43 N
C) 68 N
D) 35 N
F=ma
F=MA
90=(11+17)a
a= 3.2 m/s^2
Since you have to find out the force exerted by the 11-kg box
F=11(3.2)
F=35N
This was a question on a quiz. All my friends got 55N.
1...3.2m^s^2 is the correct acceleration for both boxes together
2...If you now draw afree body force diagram for both boxes you will see that the 11Kg box has two forces on it the resultant being 90-F where F is the force that the 17 Kg box puts on the 11Kg box
3...There is just one force on the 17Kg box ie F (Newtons 3rd law)
4...In your final step you chose to consider the 11Kg box but you should have wrote
90-F=11a.If you had chosen the 17Kg box you could write F=17a
Oops, I missed that last bit. Yes, 17x3.2 rather than 11x3.2.
Thanks for the reply
I don't understand what the force by the 17kg box on the 11kg box is.
The force wil be the same ie 55N. The left hand box pushes to the right with 55N and the right hand box pushes to the left with 55 N(3rd law )The result is that the left hand box has two forces :90 N pushing to the right and 55N pushing to the left making a resultant of 90N-55N.The right hand box has the single force of 55N pushing right.It would probably help if you sketched it out and marked in the forces.
1. What is an "easy question"?
An easy question is one that is generally considered simple or straightforward to answer. It may require minimal thought or knowledge to arrive at the correct answer.
2. How can an easy question be confusing?
An easy question can be confusing if it is worded in a way that is unclear or if it includes multiple parts or layers of complexity. It can also be confusing if the person answering it overthinks the question or second-guesses themselves.
3. Can an easy question have a subjective answer?
Yes, an easy question can have a subjective answer if it pertains to personal opinions or experiences. However, if the question is fact-based, there is usually a clear, objective answer.
4. How can I approach an easy question that is confusing me?
One way to approach an easy question that is confusing you is to break it down into smaller parts and focus on one aspect at a time. You can also try rephrasing the question or asking for clarification if needed.
5. Are there any strategies for avoiding confusion with easy questions?
Yes, some strategies for avoiding confusion with easy questions include reading the question carefully and paying attention to key words, avoiding overthinking or overcomplicating the question, and taking the time to think before responding.
