Easy question
  • Thread starter Maxwell
Just a quick question -
If I throw a ball up in the air, will the velocity be the same coming down as it was going up? Also, will the acceleration change?
Why does this happen?
Thanks.
Answers and Replies
krab
No, it won't. You said "up in the air", so there will be air resistance slowing it down and it will come down more slowly than it went up. To get the idea, throw a badminton birdie or a feather up as hard as you can. For baseballs, and small thrown heights, however, the difference may not be noticeable.
What if you neglect air resistance?
Ba
101
If you neglect air resistance the ball will be at the same speed as it comes past the place where it was released upwards just going in the other direction and the acceleration is still g, 9.8 m/s^2
The acceleration doesn't change. I'm assuming that you're still on the surface of the Earth of course.
The acceleration due to gravity never changes and is always 9.8 m/s2. Neglecting air resistance, we can therefore reason that the speed of the ball at a certain vertical height when thrown up is the same as its speed at the same vertical height when it falls to earth after being thrown. The velocity, however, changes because the ball is no longer moving in the same direction.
Related Threads on Easy question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
