Easy Thermo Question
  • Thread starter suspenc3
An Ideal monatomic gas at initial temperature [tex]T_0[/tex] (in Kelvins) expands from initial volume [tex]V_0[/tex] to volume [tex]2V_0[/tex] by each of the 5 processes indicated in the T-V diagram. In which process is the expansion a.)isothermal, b.) isobaric or c.)adiabatic? Explain your answers.
d.) In which process does the entropy of the gas decrease.
So far Ive said that AE is isothermal, initial and final temperatures are the same.
AC is isobaric, Pressure remains constant
AE is adiabatic, no heat flows in or out of the sytem
Is this right?
I dont know what to do for d.)...
Answers and Replies
huh??? Could you restate the question.
wow, sorry. I dont know how that happened? I only hit reply once.
*edit* problem resolved
Is adiabatic expansion a heating or cooling process?
See edited original post and Attachment.
Andrew Mason
7,714
419
Is this right?
I can't see your diagram yet, but I expect there are 3 choices: a horizontal line (T = constant), a curve where T/V = constant and a curve that goes below that (lower final T) where [itex]T/V^{\gamma-1}[/itex] = constant. I think you can determine from that whether your answers are right.
For adiabatic dS = dQ/T = 0. But for the others, which way does the heat flow?
AM
Andrew Mason
7,714
419
Now that I see your graphic of the question, you should check your answer to c).
If volume increases and temperature remains constant, dU does not change but the system does work (dW = PdV). So what can you say about dQ? What is the condition for dQ if it is adiabatic?
AM
Related Threads on Easy Thermo Question
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
