• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Easy thermodynamics problem
This problem is supposedly easy but I just can't figure out how to do it.
A heat pump is used to heat a house and maintain it at 24°C. On a winter day when the outdoor temperature is -5°C, the house is estimated to lose heat at a rate of 80,000 kJ/h. Determine the power required to operate this heat pump
Only two equations I know are: COP = Qh/(Qh-Ql) = Qh/W
where W is the net work done (what I'm looking for).
In the book, they have an example just like it except the COP is given so all I gotta do is plug numbers in the equation and get the answer but I don't know how to do it when the temperatures are given instead of the COP.
Andrew Mason
7,506
291
Does the question also say that the heat pump operates on an ideal Carnot cycle? If so:
[tex]\Delta S = Q_H/T_H - Q_C/T_C = 0[/tex] so:
[tex]Q_H/T_H = Q_C/T_C \rightarrow Q_H/Q_C = T_H/T_C[/tex]
So [tex]COP = \frac{T_H}{T_H - T_C}[/tex]
AM
No, if it were a carnot I'd know how to do it but it doesn't say anything about that in the problem so I don't think I can just assume carnot cycle.
I think I'm wasting too much time on this problem and I have a test tomorrow. Anyone know if there's a way to solve this problem if it were not a carnot cycle?
Thanks.
Andrew Mason
7,506
291
Not possible. It would depend on the details of the thermodynamic cycle used. Without knowing that, you cannot answer the question. I would suggest that you assume a Carnot cycle.
AM
Alright. So, assuming it's a carnot cycle, this is how it should be solved:
80,000 KJ/h = 2.22 KW
COP = Th/(Th-Tc) = 297 k/(297 k-268 k) = 10.24
COP = Qh/W ---> W = Qh/COP
W = 2.22 KW/10.24 = 2.17 KW which should be equal to the power needed to operate the pump.
Did I do anything wrong?
Andrew Mason
7,506
291
Just that Qh = 22.2 kW but your answer is right.
AM
231
Yes, that is right except as Andrew explained.
Aight thanks. You guys said that Qh isn't equal to 22.2 KW because that would be Qh/time. The units for Qh should be in KJ or J's I guess right?
231
No, Qh is indeed 22.2kW but you said 2.22kW
oh...I should probably go to bed now because my internal energy is going up, info in my head is starting to vaporize, my brain is becoming superheated, volume not changing since my skull is rigid, pressure increasing, enthalpy going up, aaaand I need to get some rest to cool down and condense the info again so it's usable by the time of the test. :zzz:
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
