Homework Help: Easy? Trignometry question
  1. Sep 27, 2009 #1
    Solve the following equations or inequalities in the interval [0, 2pi).
    2sin2x - 5sinx + 3 < 0
    2. Relevant equations
    3. The attempt at a solution
    (2sin2x - 3)(sinx - 1)
    sinx = 3/2 or sinx = 1
    Not sure what to do now
    sinx = 3/2 is impossible?
    sinx = 1 then x = 90 = pi/2
  3. Sep 27, 2009 #2
    lanedance
    just correcting your square...
    2sin2x - 5sinx + 3 = (2sinx-3)(sinx-1)
    However rather than finding the bounding points (=0, though your thinking was correct) you have an inequality
    (2sinx-3)(sinx-1) < 0
    so what conditions need to be satisfied for (2sinx-3)(sinx-1) to be negative?
  4. Sep 28, 2009 #3
    Do I need to sub in points to see rather it is positive or negative before and after sinx - 1?
  5. Sep 28, 2009 #4
    Mark44
    Staff: Mentor
    Your inequality in factored form is (2sinx-3)(sinx-1) < 0.
    As you have already noticed, the first factor can't be zero, which means that it is either always positive or always negative, no matter what x value you substitute. Determine which of these it is.
    For the product of the two factors to be negative, they have to be opposite in sign.
  6. Sep 28, 2009 #5
    lanedance
    following on from what Mark said, if the sin's are confusing, first solve for y, ie
    (2y-3)(y-1)<0
    then translate that to the original problem, by y = sinx, knowing that only y values in the range [-1,1] are allowable solutions for x
  7. Sep 28, 2009 #6
    So I think that (2sinx-3) is always neagative, this means that I need to find values of x where (sinx -1) is positive to satisfy the inequality?
  8. Sep 28, 2009 #7
    lanedance
    sounds like you're on the right track to me
  9. Sep 28, 2009 #8
    Does this mean I need to solve sinx > 1?
    I don't think there are any values where sinx > 1. Or am I confused about what I'm doing?
    sinx is 1 when x is 90
  10. Sep 28, 2009 #9
    Mark44
    Staff: Mentor
    sin(x) = 1 when x = (90 + k*360) degrees, but are there any values of x for which sin(x) > 1? If you're not sure, see lanedance's post 5.
  11. Sep 29, 2009 #10
    What happens if there are no values where sinx > 1?
  12. Sep 29, 2009 #11
    Then the inequality has no solutions.
Loading...
