• Support PF! Buy your school textbooks, materials and every day products via PF Here!
Eddy Currents
  • Thread starter carpelumen
1. Homework Statement
A magnet of mass 0.10 kg is dropped from rest and falls vertically through a 35.0 cm copper tube. Eddy currents are induced, causing the copper to warm up. The speed of the magnet as it emerges from the tube is 1.50 m/s. How much heat energy is dissipated to the environment?
2. Homework Equations
E = mgh
3. The Attempt at a Solution
h = 35 cm --> .35 m
E = (.10 kg) * (9.81) * (.35 m) = .3433 J
Is the equation incorrect?
ehild
15,362
1,768
E = mgh
h = 35 cm --> .35 m
It is the initial energy if you take the potential energy zero at the bottom of the tube. But what is the loss of energy?
ehild
NascentOxygen
Mentor
9,216
1,057
E = mgh
h = 35 cm --> .35 m
What happens to the P.E. that you have just calculated the magnet loses?
An illustrative experiment on this issue
rude man
Insights Author
667
Good! We note that a larger-diameter tube slows the magnet down more than a smaller-diameter one, following emf = -dΦ/dt. Also that Cu slowed the magnet down more than did Al or brass, following i = emf/R. Vielen Dank!
rude man
Insights Author
667
E = mgh
h = 35 cm --> .35 m
That's the kinetic energy (k.e.) that would have developed in the absence of the copper tube. What was the k.e. with the tube?
Want to reply to this thread?
"Eddy Currents" You must log in or register to reply here.
Related Threads for: Eddy Currents
  • Posted
  • Posted
  • Posted
  • Posted
  • Posted
Physics Forums Values
We Value Quality
• Topics based on mainstream science
• Proper English grammar and spelling
We Value Civility
• Positive and compassionate attitudes
• Patience while debating
We Value Productivity
• Disciplined to remain on-topic
• Recognition of own weaknesses
• Solo and co-op problem solving
