RAHIL008
- 18
What happens to the level of water in a beaker when a block of ice floating in it, melts?
Does it go up, down or remains same?
What is the reason?
What is the reason?
What do you think and why?RAHIL008 said:What happens to the level of water in a beaker when a block of ice floating in it, melts?
Good.RAHIL008 said:Sir first thought that comes in my mind is that level should remain intact as volume displaced by ice cube will be compensated by the water in it(Archimedes principle).
If ice wasn't less dense than water it wouldn't float, would it? But how does that change your conclusion from Archimedes' principle?But at second thought, i heard that ice is lesser dense than water, in that case level should come down.
I do.RAHIL008 said:But do you want to say that that virtue of ice being lesser dense does not affect the fact of Archimedes principle?
Archimedes' principle states that the buoyant force experienced by a submerged object will equal the weight of the displaced fluid. Since the ice is floating, the buoyant force must exactly equal the weight of the ice.But I think that Archimedes principle applies only to an object of particular volume being submerged or taken out of liquid, but here, the object taken out is also releasing some liquid as well.
No. Note that a given amount of ice will melt to an equal weight of water.So, in that way, level should rise, shoudn't it?
RAHIL008 said:Ok,I got it, if ice would have been denser than water(like a stone or something), it would have sunk.
Untrue, and that's the entire point. The amount of water displaced by the floating ice is equal to the volume of water obtained from melting that ice. (Note that only part of the ice is displacing fluid--the part under the water surface.)Grimstone said:displacement value of the liquid vs the displacement value of the solid.
the water level would go down.
The ice has a larger displacement value than the liquid it is made of.
simplest (original) scenario
Studiot said:After all what is molten ice?
Doc Al said:Untrue, and that's the entire point. The amount of water displaced by the floating ice is equal to the volume of water obtained from melting that ice. (Note that only part of the ice is displacing fluid--the part under the water surface.)
Grimstone said:The water in the ice tray is up to the top of each "cube".
Water freezes and it expands. this is why your Pepsi can explodes.
this is also why your water bottle can and often will break.
want to test this? take a mason jar, fill it to the lip. cap it and freeze it. be ready for the clean up.
I don't have to know the formula's to know that water expands as it freezes, thus its displacement value is greater than it started.
Thus the water level would drop.
Grimstone said:we are still talking about a beaker and a ice cube.
If a iceberg was used, I would nod in agreement with you.
But place a ice cube in your tea, and all but a smidgen is under the surface.
Grimstone said:Water freezes and it expands. this is why your Pepsi can explodes.
Born2bwire said:That is because there is only a slight difference in the density between ice and water. Salt water has a higher density than pure water and thus the relative difference between the density of salt water and ice is greater. Regardless, the fact that a smidgen is above the surface is enough here. As long as some of it is above the surface then we know that the water level will not change upon melting. If the ice cube did not float but sank then we could not make the same assumption (or if the liquid was not the same substance as the cube).
What is the reason?
kchikage said:So, even if ice floats 10% in liquid water, the weight it displaced in the water is still equal to the weight it is and will has when it melts to liquid.
Grimstone said:Then we have a lack of information.
A. Rahil did not say if the water was salty.
B. he did not state that the water had been taken from the beaker, then frozen.
C. I myself did not say that the density of the ice is what breaks the jar. it is the expansion of the ice as if freezes.
D. I would have to say the test is invalid due to lack of founding facts.
E. Also it was not stated if the water was marked before or after the ice was added.before. then its going to go up. (you added water).
After it will go down. (due to displacement. or lack there of)
Unless the ice's density is higher than water, with a higher displacement value.
of which case the water level would go up, based on more water being added to the beaker.
Grimstone said:I'm not debating this for the fun of it. I am actually trying to learn as well. If I am in error, I like to know so. and learn from my mistakes.
As i understand, the displacement value of a object is more about the volume it takes up. not its mass.
a 1inch cube of steel and a 1 inch cube of lead would displace the same amount.
right?
An ice cube has a higher volume than an equal mass of liquid water. But the amount of water that a floating ice cube displaces is the amount of its volume under the water surface. That turns out to be exactly equal to the volume of water that will be created when that ice cube melts.Grimstone said:I just know that ice has a higher displacement value than water its self.
sophiecentaur said:I'm off for a bath. If I displace more than the available freeboard of the bath, it may overflow. I shall then leap out and run naked down the street shouting Eureka. I shall call all of you in my defence to the Magistrate.
Doc Al said:An ice cube has a higher volume than an equal mass of liquid water. But the amount of water that a floating ice cube displaces is the amount of its volume under the water surface. That turns out to be exactly equal to the volume of water that will be created when that ice cube melts.
Grimstone said:How many can agrea with Doc Al?
When ice melts in a beaker, the water level will increase. This is because the volume of the ice is greater than the volume of the same amount of liquid water. As the ice melts, it takes up less space and therefore the water level rises.
This change in water level is due to the differences in density between ice and liquid water. Ice is less dense than water, meaning that it takes up more space for the same amount of mass. When the ice melts, it becomes liquid water which is more dense and takes up less space, causing the water level to rise.
Yes, the amount of ice does affect the water level in the beaker. The more ice there is, the greater the change in water level will be when it melts. This is because a larger amount of ice will take up more space when it melts, causing a greater increase in water level.
Pressure does not directly affect the change in water level when ice melts. However, as the ice melts and the water level rises, there may be a slight increase in pressure at the bottom of the beaker due to the weight of the water. This pressure increase is minimal and does not have a significant impact on the overall experiment.
Yes, this experiment can be replicated with other substances besides water and ice. Any substance that undergoes a phase change from solid to liquid, such as wax or butter, will exhibit similar changes in water level due to differences in density. However, the amount of change in water level may vary depending on the specific substance used.
