Effective Mass & Its Effects on Crystalline Structures
In summary, effective mass is a concept that uncouples one many body problem into a set of one body problems that are more easy to solve. It effects the electrical and optical properties of a crystaline structure by determining the curvature of the energy-band near the bottom.
pwerk
what is effective mass? and how does it effect both the electrical and optical properties of a crystaline structure?
Hell pwerk. Welcome to the forums. If this is a homework question, it is best to post it in the homework section. Otherwise:
Assuming that you are talking about electrons in a lattice, the effective mass is a heuristic way to relate the quantum behaviour of these electrons to a semi-classical picture. For example, you can say things like the momentum of the electron is the mass * velocity -- for suitably defined notions of velocity. Similarly, many classical electrodynamics results, e.g. optical response of plasmas, can be directly applied, by substituting the effective mass in.
Intuitively, effective mass is a concept that uncouples one many body problem into a set of one body problems that are more easy to solve (i mean, of which the Schrödinger equation, ie the SE, is easier to solve).
Suppose you have 100 electrons mutually interacting through a coulombic potential. The SE cannot be solved exactly because of the mutual coupling between all the electrons (electron 1 interacts with electron 2,3, etc). To uncouple this many body system, we convert it into a system where you have "new electrons" interacting in a background potential. So, you look at the problem as if the new electrons are no longer interacting with each other but with some background potential. Since both systems need to be equivalent (ie you need to describe the same physical reality) you need to compare both systems : the original system as mutually interacting electrons, the new system has non interacting electrons in a certain potential well. To make sure that both systems are equivalent, we change the mass of the electrons in the second system, in such a way that both SE are describing the same reality. This new mass is the effective mass, which can be defined as the electron mass + some interactions (ie energy of those interactions) to uncouple the many body problem into many one body problems.
That is the philosophy behind effective mass.
marlon
In vacuum you have Newton's second law relating force, velocity (through acceleration) and mass.
In a crystal you have a similar relationship between an external force, a group velocity and an effective mass.
To get more profound you will need quantum mechanics.
Lydia Alvarez
In band structure calculations the effective mass is basically the curvature of the energy-band near the bottom.
In (isotropic homogeneous) fermi liquid theory the effective mass is due to particle interactions.
If you want to take into account both the periodic crystal potential (thus band structure) and particle interactions then the effective mass depends on both and can't be separated in a simple way.
cheers.
1. What is effective mass and how does it affect crystalline structures?
Effective mass refers to the mass of an electron or hole in a crystalline structure, which can be different from its actual mass in free space due to interactions with the surrounding lattice. This affects the properties of the material, such as its electrical conductivity and optical properties.
2. How is effective mass measured in a crystalline structure?
Effective mass can be measured through various experimental techniques such as Hall effect, cyclotron resonance, and specific heat measurements. The results from these experiments can be used to calculate the effective mass of the carriers in the material.
3. What factors affect the effective mass in a crystalline structure?
The effective mass in a crystalline structure can be influenced by various factors, including the type of crystal lattice, the presence of impurities or defects, and the strength of electron-phonon interactions. Temperature and external electric or magnetic fields can also affect the effective mass.
4. How does effective mass impact the electronic properties of a material?
The effective mass of the carriers in a material affects its electronic properties, such as its conductivity, mobility, and bandgap. For example, a lower effective mass can lead to higher carrier mobility, making the material a better conductor.
5. Can the effective mass be engineered in a crystalline structure?
Yes, the effective mass can be engineered in a crystalline structure through techniques such as doping, strain engineering, and quantum confinement. This allows for the control and optimization of the material's electronic properties for specific applications.
  • Atomic and Condensed Matter
  • Classical Physics
