Effective Potential in Lagrangian & Hamiltonian Mechanics
In summary, the difference in sign for the effective potential in Lagrangian and Hamiltonian mechanics is due to the choice of whether to identify it from the Hamiltonian or the Lagrangian. This choice is based on the need for the negative spatial derivative of the effective potential to equate to the effective force felt by the mass.
gau55
In Lagrangian and Hamiltonian mechanics it's common to define part of the kinetic energy as the "effective potential energy" but i am unclear on which expression we define this from, if we look at the lagrangian and identify the part of the kinetic energy that's dependant only on the the generalised coordinate and not velocity to be part of the effective potential, we get a different sign for one of the terms in V(eff) than if we do the same thing when looking at the lagrangian. From my experience in scleronimic systems where the hamiltonian is the total energy and is constant it is correct to identify the effective potential from the hamiltonian, whereas when energy is not conserved we choose to identify the effective potential from the lagrangian. They are always different in sign and from this i conclude that in the first case it is only correct to take it out of the hamiltonian and its wrong to do it the other way, and vice versa in the second case i described. My question is what is the difference that causes all of this and how is this choice the result of the need for the negative spatial derivative of the effective potential to equate to the effective force felr by the mass
Well, the most common case is treating angular momentum as producing a modification of the potential.
Many classical situations are described by an energy equation:
[itex]KE + PE = E[/itex]
where [itex]KE[/itex] is the kinetic energy, and [itex]PE[/itex] is the potential energy. In polar coordinates [itex]r, \theta[/itex], the kinetic energy for motion in a plane is given by:
[itex]KE = \frac{m}{2} \dot{r}^2 + \frac{L^2}{2mr^2}[/itex]
where [itex]L[/itex] is the angular momentum. The angular momentum term is the kinetic energy due to angular velocity and the other term is due to radial velocity.
I don't think that there is anything deeper about "effective potentials" than just pretending that [itex]\frac{L^2}{2mr^2}[/itex] is a kind of repulsive potential energy:
[itex]PE_{eff} = PE + \frac{L^2}{2mr^2}[/itex]
Then the energy equation becomes (since [itex]L[/itex] is a constant) an effective one-dimensional equation:
[itex]KE_{r} + PE_{eff} = E[/itex]
Writing it out explicitly:
[itex]KE_{r} = \frac{1}{2} m \dot{r}^2[/itex]
[itex]PE_{eff} = V(r) + \frac{L^2}{2mr^2}[/itex]
where [itex]V(r)[/itex] is the real potential.
Treating the angular momentum term as part of the potential, instead of kinetic energy, is exactly analogous to treating "centrifugal force" as part of the force, rather than part of the acceleration.
1. What is the purpose of the effective potential in Lagrangian and Hamiltonian mechanics?
The effective potential is a mathematical tool used to simplify the equations of motion in Lagrangian and Hamiltonian mechanics. It allows for the elimination of certain variables, making the equations easier to solve and providing a deeper understanding of the system's behavior.
2. How is the effective potential related to the potential energy in a system?
The effective potential is directly related to the potential energy in a system. It is a combination of the potential energy and the kinetic energy, and it represents the total energy available to a particle in a given system.
3. Can the effective potential be negative?
Yes, the effective potential can be negative. This means that the total energy available to a particle in the system is less than zero, and the particle is confined to a region where the potential energy is greater than the kinetic energy.
4. How does the shape of the effective potential affect the motion of a particle?
The shape of the effective potential determines the type of motion that a particle will have in a system. For example, if the effective potential has a minimum point, the particle will have stable equilibrium and oscillate around that point. If the effective potential has no minimum point, the particle will have unbounded motion.
5. Can the effective potential be used to analyze systems with multiple particles?
Yes, the effective potential can be extended to analyze systems with multiple particles. In this case, the effective potential will depend on the positions and velocities of all the particles, and it can be used to determine the motion of each particle and the interactions between them.
  • Mechanics
