Effective Reynolds Number for a swept wing
In summary, the forces per unit length (parallel to leading edge) become: L=q⋅cos2Λ⋅c⋅cl, D=q⋅cos2Λ⋅c⋅cd.
Murmur79
Suppose we have an infinite straight wing, using a given airfoil. Also, suppose for simplicity the B.L. is completely turbulent, and M<<1 (incompressible fluid).
As we know, the forces per unit length are: L=q⋅c⋅cl, D=q⋅c⋅cd, where cl and cd are the coefficients of the 2D airfoil for the given Re and α.
Now, if we rotate the infinite wing of an angle Λ, we have an infinite swept wing.
The theory says that in this case, the forces per unit length (parallel to leading edge) become: L=q⋅cos2Λ⋅c⋅cl, D=q⋅cos2Λ⋅c⋅cd.
Here is my question:
when looking up the cl and cd for the 2D airfoil, should we use:
.) the Re for the unswept wing: Re=U⋅c/ν
.) the Re normal to leading edge: Re=U⋅cosΛ⋅c/ν
.) the Re parallel to the flow: Re=U⋅(c/cosΛ)/ν
Ok, meanwhile a simpler example came to my mind.
Consider a flat plate of infinite length and chord c at zero incidence. Incompressible flow and 100% turbulent B.L.
In this case, we know that, for example, the thickness of the B.L. at the trailing edge will be δ=f(Re).
Now we rotate the flat plate of angle Λ.
What will the new B.L. thickness be at the trailing edge? What Re does it make sense to use between the 3 options given above?
I'll make a few comments here. First, a swept flat plat behaves very differently than a swept wing. The latter has spanwise pressure gradients. The former does not.
Second, for a wing swept at a fixed ##\Lambda##, do you expect the Reynolds number trends to change whether it (a constant) is included in the Reynolds number or not?
hi bone3ead,
yes, I realized the two cases are different. Let's consider the simpler example of the flat plate. In this case, the spanwise/chordwise gradients should be minimized.
I was wondering, for the experiment described above, which one between the three Re definitions, would give the closest results to the actual B.L. thickness at the trailing edge in the swept flat plate, _in the hypothesis_ that we use the same formula for the B.L. thickness in the two cases (swept/unswept).
I know that using the same formula has no theoretical basis at all, and could (intuitively) only be reasonable if the B.L. characteristics are not much changed, hence the hypothesis of the flat plate which should minimize spanwise effects.
In other words, I'd be curious to know what would happen at the thickness of the B.L. if we sweep a flat plate from 0 to say 45 or 60 degrees, and if there is a new specific Re that can predict the result without changing the formula used for the unswept flat plate.
1. What is the definition of Effective Reynolds Number for a swept wing?
The Effective Reynolds Number for a swept wing is a dimensionless number that represents the ratio of inertial forces to viscous forces in the flow over a swept wing. It takes into account the effects of sweep angle and aspect ratio on the flow over the wing.
2. How is Effective Reynolds Number calculated for a swept wing?
The Effective Reynolds Number is calculated by multiplying the local Reynolds Number by a correction factor, known as the sweep efficiency factor. This correction factor takes into account the change in flow direction and the reduction in effective wing area due to sweep angle.
3. What is the significance of Effective Reynolds Number in aerodynamics?
The Effective Reynolds Number is an important parameter in aerodynamics as it affects the lift and drag characteristics of a swept wing. A lower Effective Reynolds Number means that the flow is more laminar and the wing experiences less drag. It also affects the boundary layer transition and the formation of shock waves.
4. How does the Effective Reynolds Number change with different sweep angles and aspect ratios?
The Effective Reynolds Number decreases as the sweep angle and aspect ratio of the wing increase. This is because higher sweep angles and lower aspect ratios result in a higher sweep efficiency factor, which reduces the effective wing area and increases the viscous forces in the flow.
5. What are the limitations of using Effective Reynolds Number for swept wings?
The Effective Reynolds Number is only applicable for wings with sweep angles less than 60 degrees and aspect ratios greater than 2. It also assumes a steady, incompressible flow and does not take into account other factors such as airfoil shape, surface roughness, and wing twist. Therefore, it should be used as a guide and not as an exact predictor of aerodynamic behavior.
  • Classical Physics
  • Mechanical Engineering
  • Aerospace Engineering
  • Other Physics Topics
12K
