Homework Help: Efficiency of Diesel cycle
  1. Apr 15, 2013 #1
    Derive a formula for the efficiency of the Diesel cycle, in terms of the compression ratio V1/V2
    2. Relevant equations
    e=[itex]\frac{W}{Q_{h}}[/itex]
    w= ∫pdV
    3. The attempt at a solution
    Now I know I should have used e=1-[itex]\frac{Q_{c}}{Q_{h}}[/itex] to get it but he said it is possible using e=[itex]\frac{W}{Q_{h}}[/itex]
    I know that W_{4-1} is equal to zero and W_{2-3} is equal to P_{2}(V_{3}-V_{2})
    what I don't know is how he got
    W_{1-2} = [itex]\frac{e}{1-δ}[/itex]*cv[itex]^{-δ+1}[/itex] = [itex]\frac{1}{1-δ}[/itex]*(P_{2}V_{2}-P_{1}V_{1})
    and
    W_{3-1} = [itex]\frac{e}{1-δ}[/itex]*cv[itex]^{-δ+1}[/itex] = [itex]\frac{1}{1-δ}[/itex]*(P_{4}V_{4}-P_{3}V_{3})
  3. Apr 15, 2013 #2
    DrClaude
    Staff: Mentor
    What are points 1,2,3, and 4? What is ##\delta##?
  4. Apr 15, 2013 #3
    1,2,3 and 4 are the strokes of the cycle. Well the different points on the picture. and δ is supposed to be gamma, which is the adiabatic exponent.
    I thought I could use
    W=∫pdV = C[itex]_{v}[/itex](T[itex]_{1}[/itex]-T[itex]_{2}[/itex]
    for the compression stroke...but I guess that is incorrect
  5. Apr 15, 2013 #4
    DrClaude
    Staff: Mentor
    You have to be more specific. The numbering of points on a cycle is arbitrary. For each part of the cycle, state something like: 1→2 isothermal expansion at ##T_2##.
  6. Apr 15, 2013 #5
    From 1→2 is compression
    From 2→3 is fuel injection/combustion
    From 3→4 is the power stroke
    From 4→1 is exhaust
  7. Apr 15, 2013 #6
    Andrew Mason
    The ideal diesel cycle consists of a constant pressure expansion (2-3) followed by an adiabatic expansion (3-4) followed by constant volume cooling (4-1) followed by adiabatic compression (1-2).
    So heat goes in only from 2-3 and heat goes out only from 4-1. Since W = Qh-Qc and η = W/Qh = 1-Qc/Qh you just have to deal with the two parts in which heat flows (ie. 4-1 and 2-3).
    Can you work out Qh and Qc? (hint: it involves temperature change and heat capacity).
    AM
Have something to add?
Draft saved Draft deleted
