Egg car project help!
  • Thread starter Maleeha
for class we have to make a car with an egged attached to the front (so its protruding). the car has to be able to stop on its own and travel distances of 6m, 8m, 10m, and one even numbered mystery distance between 5m and 10m. compressed gases, explosives, and premade parts may not be used. i have no idea where to even begin :(
Answers and Replies
Delphi51
3,407
Think of several ways of storing energy that are allowed and think about how to implement each. Likely one will stand out as being relatively easy to set up. You will need a fairly good range of adjustment to cover all those target distances.
im currently thinking of using rubber bands to turn the axle, but im not sure if that will be able to go far enough
Delphi51
3,407
It probably can be done with elastic bands. A quick measurement of the F and maximum x would give you an idea how much energy can be stored in the prospective elastic and you could compare that to the work needed to pull the car. That way you can choose an appropriate size for the elastic(s) before building.
You might try springs or weights at a height.
Related Threads on Egg car project help!
  • Last Post
  • Last Post
9K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
29K
  • Last Post
10K
  • Last Post
