Can You Engineer an Egg Drop Device to Survive a 14m Fall?
In summary, the student was thinking of ways to make an egg drop device that is the fastest and survives the fall. They were thinking about different materials and how to disperse the force of the egg.
Jbreezy
582
I have to make an egg drop device. I was fishing for ideas. It needs to be the fastest time and survive the fall. If I win I get 4 points E.C..
Impulse = Ft
Position function for falling object
s(t) = -16t^2 +Vo + So
s'(t) = -32t
F = ma
p = mv
Where p is momentum
The equations above are just things that pop into my head that might help me solve this.
So far I have been thinking about peanut butter in a jar or something along those lines. Maybe layers of different materials to disperse the force that the egg gets.
This is my brain storm so far. Does anyone have any ideas??
Thanks
Maybe corn starch and water in a dilute mix. I don't know what the normal mixture is but what ends up happening to the fluid is that it solidifies when subject to stress. Depending on the mixture it could solidify so much that if you punch it not even your hand will go through it. If you make it dilute enough I could see it maybe slowing the egg while not breaking it.
I like the peanut butter idea though, might not work though depending on how large of a drop it is. That said, how high is the drop? Do you have to design a release mechanism as well?
It seems to me the most important piece of information is how much force/area is required to break an egg and is it the same on the end of the egg as it is for the side. Your solution occurred to me too but I thought of using gelatin mixed to the same density as the egg.
OK guys, the drop is 14.3 meters it off a parking structure.
I have thought more too. I like the ideas thanks. I do not have to make a release mechanism. I was thinking of a capsule type idea that could be composed of different layers The outer most could be extremely hard but absorbent material. Then the next layer could be something less...and then around the egg I would need something like the ideas you guys have generated. The gelatin, peanut butter ect...still thinking
The reason I said the most important information is how much force/area is required to break an egg is to calculate the maximum deceleration rate of the egg when it hits the ground.
Let's make some guesses. Suppose the minimum non-symmetrical force required to break an egg is 3.5 N/cm^2 and suppose the capsule is traveling at about 28.6 m/s when it hits the ground. You are going to have to decelerate the egg from 28.6 m/s to 0 in a distance less than half the diameter of your capsule without exceeding a non-symmetrical force of 3.5 N/cm^2. By non-symmetrical I mean that the force at one point on the egg is greater than the force on the rest of the egg. Can you calculate how large your capsule must be to do that?
Presumably you could apply a relatively uniformly high force on all sides of the egg without it breaking. Even that would have a limitation because there is a pocket of gas in the egg.
P.S. You specify the height in meters but your formulas are for English measurements. Serious mistakes have been made by mixing systems of measurements. You should always solve your whole problem using the same system of measurement.
Skeptic2,
I'm going to google the the non-symmetrical force required to break an egg. I was thinking about this with my dad we were thinking to have a sort of rocket and have the cone able to crumble and absorb the impact of the drop we had the idea to start the egg the furthest away from tip of the cone. This will allow us max distance to stop the egg. We are still thinking of the idea for the inside. We were thinking of another type of tube on the inside. This is still rough.
Please let me know any ideas that come to mind with this brain storm.
Thanks,
I forgot about the measurments...not good. thanks
Skeptic2 ,I have been googling non symmetrical force required to break an egg. It is funny it just takes me to your post on here.
Does anyone know this ?
Thanks
I'd say your best bet will be to just start building and testing out some different materials. This sounds like an engineering project more than anything. I know this is a physics forums but I'd say worry about that stuff later. Aside from the basics, like how fast the egg will be moving when it reaches your contraption. Doing exact calculations/experimental testing on the egg is not feasible at least in my opinion.
I think you should stick with something like the peanut butter idea. Though with a 14m drop you are probably going to need a softer fluid (less viscous) perhaps. Something like Fluff (marshmallow spread) might actually work better. Skeptics idea about the gelatin is also a really good one, you could test out different gelatin mixtures.
I would say start by testing at a 2 meter drop, something small at first and test out a couple different types of material. Peanut butter and Fluff will probably get really expensive and annoying if you have a bunch of eggs breaking in them. For that reason gelatin or the corn starch and water might be more efficient.
Best of luck!
1. How does an egg survive a fall?
The egg survives a fall due to the principle of inertia. When the egg is dropped, it has a tendency to remain at rest or in motion unless acted upon by an external force. This means that the egg will continue to move downward at a constant speed until it encounters another force, such as the ground or a cushioning material, that slows its descent.
2. How can I design a successful egg drop contraption?
There are several key factors to consider when designing an egg drop contraption. These include the materials used, the structure's strength and stability, and the cushioning materials. It is also important to test and adjust the design before the actual drop to ensure its effectiveness.
3. What are some common materials used in egg drop contraptions?
Some common materials used in egg drop contraptions include straws, popsicle sticks, rubber bands, and paper cups. These materials are lightweight and can easily be assembled into a structure that can cushion the fall of an egg.
4. How can I protect the egg during the fall without adding too much weight to the contraption?
To protect the egg without adding too much weight, it is important to use lightweight and shock-absorbent materials such as foam, cotton, or bubble wrap. These materials can provide sufficient cushioning while keeping the overall weight of the contraption low.
5. Can I use any type of egg for an egg drop experiment?
Yes, any type of egg can be used for an egg drop experiment. However, it is important to ensure that the egg is not cracked or damaged before the drop. It is also recommended to use a raw egg rather than a hard-boiled one, as the raw egg will absorb more impact and provide a better representation of real-life scenarios.
11K
18K
14K
