Eigenvalue Q: What if ##\lambda=0##?
  • Thread starter matematikuvol
  • Tags
    Eigenvalue
In summary, if ##\lambda=0##, then \hat{A} is not invertible, so ##\hat{A}^{-1}## makes no sense. Additionally, for any matrix ##A##, only one of the following can be true: either ##X## is an eigenvector of ##A## with eigenvalue zero and ##X \ne 0##, or ##A## is non-singular and ##X=A^{-1}0=0##. To have an inverse, a matrix must be associated with a one-to-one linear transformation, meaning it cannot map any vector to zero.
matematikuvol
192
If ##\hat{A}\vec{X}=\lambda\vec{X}## then ##\hat{A}^{-1}\vec{X}=\frac{1}{\lambda}\vec{X}##
And what if ##\lambda=0##?
0 can never be an eigenvalue of an invertible matrix. So if [itex]\lambda=0[/itex], then [itex]\hat{A}[/itex] is not invertible, so [itex]\hat{A}^{-1}[/itex] makes no sense.
Is there some easy way to see that?
If ##X## is an eigenvector of ##A## with eigenvalue zero, then ##AX = 0## and ##X \ne 0##.
But if ##A## is non-singular, then ##X = A^{-1}0 = 0##.
For any matrix ##A##, only one of the above can be true.
If X is an eigenvector of A with eigenvalue zero, then AX=0 and X≠0.
But if A is non-singular, then X=A−10=0.
For any matrix A, only one of the above can be true.
To put it less formally (but perhaps less transparently if you haven't gone far in linear algebra yet), in order for a matrix to have an inverse, it has to be associated to a one to one linear transformation. If you can hit a vector, v, with a linear map T and kill it (make it zero), then you hit λv with T and kill it for any scalar λ, so the map is not one to one because the pre-image of 0 (or any other vector) contains at least one parameter worth of stuff.
1. What is the significance of ##\lambda=0## in eigenvalues?
When ##\lambda=0##, it means that the matrix has a non-invertible or singular solution, as the determinant of the matrix is equal to zero. This has important implications in solving systems of linear equations and in understanding the behavior of the matrix.
2. How does a zero eigenvalue affect the eigenvectors?
When ##\lambda=0##, the eigenvectors of the matrix are in the null space or kernel of the matrix. This means that they are perpendicular to all other eigenvectors and are not affected by scalar multiplication. Essentially, they are the "zero vectors" of the matrix.
3. Can a matrix have more than one zero eigenvalue?
Yes, a matrix can have multiple zero eigenvalues. This occurs when the matrix has repeated rows or columns, resulting in repeated eigenvalues. In this case, there are multiple eigenvectors associated with the zero eigenvalue.
4. How does a zero eigenvalue affect the diagonalization of a matrix?
If a matrix has a zero eigenvalue, it cannot be diagonalized. This is because diagonalization requires all eigenvalues to be non-zero. In this case, the matrix is called defective and cannot be fully diagonalized.
5. What are the practical applications of a zero eigenvalue?
A zero eigenvalue has many practical applications in fields such as physics, engineering, and computer science. It is used in solving systems of linear equations, analyzing the stability of systems, and in image processing. It also has important implications in quantum mechanics and the study of geometric transformations.
  • Linear and Abstract Algebra
