Eigenvalues for a Hamiltonian
  • Thread starter umagongdi
umagongdi
Consider the Hamiltonian
[tex]\hat{}H[/tex] = [tex]\hat{}p[/tex]2/2m + (1/2)mω2[tex]\hat{}x[/tex]2 + F[tex]\hat{}x[/tex]
where F is a constant. Find the possible eigenvalues for H. Can you give a physical
interpretation for this Hamiltonian?
I don't think you can put H in matrix form?
Can i use the following?
HΨ=λΨ
HΨ = p2Ψ/2m+(1/2)mω2x2Ψ+FxΨ = λΨ?
I think i am using the wrong method.
What does "give a physical interpretation..." mean?
thanks in advance
Answers and Replies
sgd37
213
Haha Russo still up to his tricks
you have to complete the square in the position operator terms to get a new position operator plus a constant term added onto the hamiltonian.
This added term means that it is a shifted harmonic oscillator
umagongdi
lol that's awsome that we went/go to the same uni, what do you do now Masters/PhD here?
As for the question, i don't understand how completing the square will help us find the eigenvalues.
Looking at
(1/2)mω2X2+ FX2
We can factorise the (1/2)mω2X2
(1/2)mω2X2(X2+FX/(1/2)mω2X2)
Looking at:
(X2+FX/(1/2)mω2X2)=(X+F/mω)2)-(F/mω2)2)
Subbing everything into original equation we get:
H=P2/2m +(1/2)mω2(X+F/mω2)2-(1/2)(F2/mω2)
umagongdi
Can we look at HΨ=?Ψ
We can rearrange and solve for Ψ?
vela
Staff Emeritus
Education Advisor
15,584
2,221
Two things:
1. If you add a constant to the Hamiltonian, what does that do to the eigenfunctions and eigenvalues?
2. Initially you had the potential V(x) and now it looks like V(x+a), where a is a constant. Physically, what does x going to x+a represent? What effect should that have on the solutions?
sgd37
213
I'm at Cambridge doing PartIII and missing the simple life at Queen Mary
anyway the Harmonic oscillator can be rearanged in terms of the number operator
[tex] \hat{H} = \frac {\hat{p}^2}{2m} +\frac {1}{2} m \omega^2 \hat{x}^2 = \hbar \omega (a^{\dagger} a +\frac {1}{2}) = \hbar \omega(\hat{n} + \frac{1}{2}) [/tex]
adding a constant to the hamiltonian does not change the eiegenstates only the eigenvalues
umagongdi
Two things:
adding a constant to the hamiltonian does not change the eigenstates only the eigenvalues
In this case is the eigenfunction HΨ=EΨ or eigenstate, what is the difference, are they the same? I am a bit confused is the whole equation HΨ=EΨ called a eigenfunction or a specific part of it?
I think i finally understood how to do it, i used the ladder operator method. I obtained this part
I dont know how to do the following:
[tex]\hbar \omega (a^{\dagger} a +\frac {1}{2}) = \hbar \omega(\hat{n} + \frac{1}{2}) [/tex]
Finally starting to understand QM, thanks you guys.
sgd37
213
the equation [tex] \hat{H} \Psi = E \Psi [/tex] is used to define the eigenfinction [tex] \Psi [/tex] with eigenvalues E
as for the number operator we derive that from the fact that
[tex] a \left| n \right \rangle = \sqrt{n} \left| n-1 \right \rangle [/tex]
[tex] a^{\dagger} \left| n \right \rangle = \sqrt{n+1} \left| n+1 \right \rangle [/tex]
these come from the conditions
[tex] a \left| 0 \right \rangle = 0 [/tex]
[tex] a^{\dagger} \left| 0 \right \rangle \propto \left| 1 \right \rangle [/tex]
and from the fact that we want the number operator to reproduce the eigenvalues of the QHO i.e. [tex] \hbar \omega (n + 1/2) [/tex]
Suggested for: Eigenvalues for a Hamiltonian
  • Last Post
  • Last Post
  • Last Post
  • Last Post
