Eigenvalues proof
  • Thread starter fluidistic
fluidistic
146
Let A=LU and B=UL, where U is an upper triangular matrix and L is a lower triangular matrix. Demonstrate that A and B have the same eigenvalues.
Not sure.
I know that if I can show that A and B are similar (so if I can find a matrix P such that P^(-1)AP=B) they have the same eigenvalues. But I didn't find P yet, nor do I know really how to search efficiently for P.
Another route I've thought of is to write det (I*lambda-A)=0 gives the same values for lambda as det (I*lambda-B)=0. I've thought of using det (A)=det (LU)=det L * det U = det U * det L = det B... but still can't reach anything I find useful.
Any tip is greatly appreciated.
Answers and Replies
lanedance
3,304
how about multiplying thorugh by the inverse of L.. you may need to show it exists
Try to write A in terms of B (or the other way around), and see what you get!
lanedance
3,304
hint was probably enough
fluidistic
146
LU=U^(-1)ULU=LU so the equality is true. Notice that LU=A and UL=B. I have that P=U, thus LU is similar to UL (A similar to B) so they share the same eigenvalues.
Now I must justify the use of the inverse of U. Well I believe its element on the diagonal are all non zero. So if the matrix is nxn, the span of its column vector is R^n so it is invertible, hence U^-1 exists.
Is that well justified?
Dick
26,263
619
It would be if the problem stated that the elements of U along the diagonal are nonzero. Does it? Other versions of this problem I've found say that L or U is a UNIT triangular matrix. Did you miss a word in the problem statement?
fluidistic
146
You pointed out a very interesting thing to me. In my assignment it isn't specified. But most of the exercises assigned are taken from Kincaid's book on numerical analysis. I just checked there and it clearly states L to be UNITARY.
If only they had stated this in my assignment I could have guessed that I had to take the inverse of L. :) Well I'm not 100% sure but probably.
So basically the problem is solved now... thanks guys.
Dick
26,263
619
Their bad. Very welcome.
Related Threads on Eigenvalues proof
  • Last Post
  • Last Post
  • Last Post
  • Last Post
12K
  • Last Post
  • Last Post
  • Last Post
  • Last Post
