Eigenvectors and eigenspaces
  1. Sep 8, 2011 #1
    Let T: M22 - M22 be defined by
    T(a b = 2c a + c
    c d) b-2c d
    (a) Find the eigenvalues T.
    (b) Find bases for the eigenspaces of T.
    2. Relevant equations
    det(lambdaI - A) = 0
    3. The attempt at a solution
    I just wanted to know how to start here. I am used to using vector transformations...
    Would I use identity matrices 1 0 0 1 0 0 0 0
    0 0 0 0 1 0 0 1
    And then form a matrix somehow? I just don't know how big or how this matrix would be formed...?
  3. Sep 8, 2011 #2
    One small thing: you shouldn't call the matrices
    [tex]\left(\begin{array}{cc} 1 & 0\\ 0 & 0\end{array}\right), \left(\begin{array}{cc} 0 & 1\\ 0 & 0\end{array}\right), \left(\begin{array}{cc} 0 & 0\\ 1 & 0\end{array}\right), \left(\begin{array}{cc} 0 & 0\\ 0 & 1\end{array}\right)[/tex]
    identity matrices. We reserve the term identity matrix for something else.
    You can call them elementary matrices however.
    Anyway, your approach is good: try to find the images of the elementary matrices to find the matrix form of T. T will have the form of a 4x4-matrix.
  4. Sep 8, 2011 #3
    Ok. So I find the matrix for T to be:
    0 1 0 0
    0 0 1 0
    2 1 0 0
    -2 0 0 1
    The characteristic equation of which I find to be:
    (lambda)4 - (lambda)3 - (lambda)2 - (lambda) + 2
    Just wondered if there was an easy way to solve this?
  5. Sep 8, 2011 #4
    Hmm, that's not what I get:
    [tex]T\left(\begin{array}{cc} 1 & 0\\ 0 & 0\end{array}\right)=\left(\begin{array}{cc} 0 & 1\\ 0 & 0\end{array}\right)[/tex]
    So the first column needs to be (0,1,0,0), no?
  6. Sep 8, 2011 #5
    O ok. So I must turn the resulting matrix into a column vector? I just put them together as matrices...my bad...ok I shall try this agen...shall get back to you to confirm my answer...thanks alot...
    Ciao...I feel mentally ill that I am such a dumb ***!...but then again...have to learn somehow...
  7. Sep 8, 2011 #6
    Ok I think I have solved it:
    The standard matrix for T is:
    0 0 2 0
    1 0 1 0
    0 1 -2 0
    0 0 0 1
    Whose characteristic equation is:
    (lambda - 1)2(lambda + 1)(lambda + 2) = 0
    This right?
    Thanks
    Derryck
  8. Sep 8, 2011 #7
    Yes, that's also what I've got!!
  9. Sep 9, 2011 #8
    Thanks alot micromass
    Tell you what if it wasn't for physicsforums I don't know how I would have passed my correspondence linear algebra course...
    Cheers
    Derryck
