How does the Einstein tensor contribute to the equations of motion in 4d?
In summary, the paper discusses the contribution of a specific term, α(R2 − 4RμνRμν +RμνρσRμνρσ), to the Einstein equations in four dimensions. This term, when added to the Einstein action, does not contribute to the equations of motion due to its variation vanishing identically. The paper also clarifies the difference between the Einstein field equations and the equation of motion in general relativity, with the latter being described by the geodesic equation.
alejandrito29
150
Hello, in a paper http://www-library.desy.de/preparch/conf/theo-ws/workshop2004/data/Chatillon.pdf .
says that.
1) In 4d, it is a total derivative, then does not contribute to the equations of motion
A total derivative respect to time does not contribute to equation of motion?, ¿or other parameter??
2) Only [tex]R^2[/tex] order combination giving equations of motion
with no derivatives of higher order than two and divergence free, like the Einstein tensor.
¿why einstein tensor gives equation of motion of second derivative of time?...I think that varying the action [tex] \int \sqrt{g_{uv}dx^u dx^v} [/tex] i get the equation of motion, but i don't understand but the einstein tensor too...
alejandrito29, One way to derive the Einstein equations is to take as the action S = ∫√-g R, and vary this with respect to gμν. It turns out that δS/δgμν = √-g Gμν. It's generally true that for any action of the form S = ∫√-g L, where L is a scalar, that δS/δgμν will be a divergence-free tensor.
The paper considers adding to the Einstein action a term α(R2 − 4RμνRμν +RμνρσRμνρσ)
In four dimensions the variation of this additional term vanishes identically, so it makes no contribution to the equations of motion.
very thank , but,
1. ¿a divergence-free tensor does not contribute to the equations of motion?
2. ¿the einstein tensor then does not contribute to the equations of motion?. I understand by Einstein equation [tex]G_{uv}= R_{uv}-\frac{1}{2}g_{uv}R=k T_{uv}[/tex] but by equation of motion [tex] \ddot{x} + \Gamma^v_{su} \dot{x}^s \dot{x}^u=0[/tex]
¡I didn't say that! A term T in the Lagrangian which can be written as a total divergence, T = Vμ, does not contribute to the equations of motion. Lagrangians are not unique. Two Lagrangians that differ by a total divergence will yield exactly the same equations of motion.
You're confusing two things that have nothing to do with each other. S = ∫√-g R d4x is the action for the field, and its variation δS/δgμν yields the Einstein equations. ∫√gμνdxμdxν is a Lagrangian that can be used to describe geodesics, and its variation yields the equations of motion for a test particle.
ok, very very thanks, but
what is the equation of motion in general relativity? [tex] G_{uv}= k T_{uv}[/tex] or [tex]\ddot{x}+ \Gamma^u_{s v} \dot{x}^s \dot{x}^v[/tex] ?,
or other??
alejandrito29 said:
or other
The first proposition you give is the Einstein's field equation.
The second proposition, if vanishing, is the equation describing a parallel transported speed vector.
Solutions of the field equation is of the following type:
gab. va. vb = constant where v is the speed of the particle and where a, b = 0, 1, 2 and 3.
If you prefer a formulation like in classical mechanics, with forces, then you have to write the equation Dv = forces to recover the solutions.
If your lagrangian is of the form [tex]L = \frac{1}{2}g_{\mu \nu }\dot{x^{\mu }}\dot{x^{\nu }}[/tex] then you can use the euler lagrange equations [tex]\frac{\partial L}{\partial x^{\mu }} - \frac{\mathrm{d} }{\mathrm{d} \lambda }(\frac{\partial L}{\partial \dot{x^{\mu }}}) = 0[/tex] (where lambda is an affine parameter) to arrive at the geodesic equation [tex]\ddot{x}^{\mu } + \Gamma ^{\mu }_{\alpha \beta }\dot{x^{\alpha }}\dot{x^{\beta }} = 0[/tex] If you use the Einstein lagrangian [itex]L = (-g)^{1/2}R[/itex] then variation of the lagrangian will yield the vacuum field equations [itex]G^{\mu \nu } = 0[/itex] and the related bianchi identity [itex]\triangledown _{\mu }G^{\mu \nu } = 0[/itex].
What is Einstein Gauss Bonnet Gravity?
Einstein Gauss Bonnet Gravity is a theory that extends Einstein's Theory of General Relativity to include higher-dimensional spaces. It takes into account the curvature of space and time, and the effects of matter and energy on this curvature.
What is the significance of the Gauss Bonnet term in this theory?
The Gauss Bonnet term is a mathematical expression that accounts for the topology of space and how it affects the curvature. It is crucial in understanding the behavior of gravity in higher-dimensional spaces.
How does Einstein Gauss Bonnet Gravity differ from General Relativity?
Einstein Gauss Bonnet Gravity takes into consideration the effects of higher-dimensional spaces, while General Relativity only applies to four-dimensional space-time. It also includes the Gauss Bonnet term, which affects the equations of motion for particles and the behavior of black holes.
What are the potential applications of Einstein Gauss Bonnet Gravity?
Some potential applications of this theory include understanding the behavior of gravity in higher-dimensional spaces, providing a framework for string theory, and explaining the origin and evolution of the universe.
What are the current challenges and limitations of Einstein Gauss Bonnet Gravity?
One of the main challenges is the complexity of the mathematical equations involved, making it difficult to test and apply in practical situations. Additionally, it is still an area of active research and there may be limitations that have not yet been discovered.
