Why Albert Einstein's Original Concept for a Black Hole?
  • B
  • Thread starter K. Doc Holiday
  • Tags
    Bridge
In summary: No, he didn't. He was the first to show that the solution couldn't exist. Didn't he?...Did Schwarzschild accept the possibility of...?No, he didn't. He was the first to show that the solution couldn't exist.
K. Doc Holiday
32
Einstein-Rosen Bridge
Question: Why do we discard Albert's original concept for a black hole? I have one college astronomy textbook which doesn't even mention it. The only use seems to be in science fiction movies and books. Why?
Is it possible that he actually got it right conceptually but discarded it because his math was off?
Whenever I look at any other conceptual drawings of a black hole I notice something. They never have ALL the component parts: relativistic jets (plural), accretion disk and event horizon. And current theory is incapable of explaining the loss of "information" which violates the laws of quantum physics. Which seems like a problem. Isn't it?
On the other hand, if we assume Albert's original concept is correct these problems seem to disappear. Should we consider going back to the basics? Just asking.
Respectfully,
Doc Holiday
The problems don't actually disappear if you roll back history to when they hadn't been discovered yet.
Likes Dale and Bandersnatch
Even if wormholes can actually exist, they would be very short lived, unstable, and microscopic in scale.
Not really a potential way of transporting people and other stuff
Well, black holes don't have to HAVE an accretion disk. If they've laready sucked in everything around them, there is no accretion disk.
A worm hole entrance is pretty easy to imagine. It appears useful to ask what a wormhole exit might look like. I don't believe any candidate examples have been identified.
Hey,. "Doc" (I put Doc in quotes because you never answered my question "what is your doctorate in" so I assume you are a pretend doc) this kind of undue and unnecessary familiarity is off-putting and doesn't actually help you make your case.
As it happens, Einstein did not invent the black hole. Classically, the idea goes back a century earlier to Laplace. The modern black hole's key property - the event horizon - was first understood in 1958, 3 years after Einstein's death. He also didn't really invent the wormhole in the paper with Rosen. That paper was more about the sort of properties charged particles can have in GR without leading to mathematical trouble. In 1962 Wheeler showed that this isn't a wormhole solution in the normal sense, in that the wormhole cannot last long enough for anything to traverse it.
Likes russ_watters
What "original concept" are you referring to?
Likes russ_watters, martinbn and Dale
I also don’t know what you are referring to here. Can you provide a citation or a link?
Isn't he talking about the Einstein-Rosen bridge (title, first line)?
You could be right, but it hardly seems like a discarded concept. It is well known and frequently discussed.
If he is, he is mistaken in thinking that it was "Albert's original concept for a black hole" which was then "discarded". AFAIK there was no such thing. So we need the OP to clarify what he is actually interested in talking about: is it the Einstein-Rosen bridge, or is it the nonexistent (unless the OP can provide a reference) "Albert's original concept for a black hole which was then discarded"? Or is it something more like "what component parts does a black hole have", or is it the black hole information loss problem?
I agree the thread title is what it is, but I see nothing whatever in the actual substance of the OP that refers to it, and several other things that appear (possibly) to be referred to in the OP. Rather than try to guess what the OP actually is interested in, I'd like him to tell us.
Just to clarify the actual history of the Einstein-Rosen bridge concept: neither Einstein nor Rosen had anything to do with discovering it. The maximally extended Schwarzschild geometry was not discovered until the late 1950's; not until after that geometry was understood was the presence of the "wormhole" now called the Einstein-Rosen bridge in it understood. The "wormhole" in that solution was named after Einstein and Rosen because of a 1935 paper they published which proposed a modified theory of gravity (i.e., a different field equation from GR) which would allow static "wormhole" solutions with normal matter only, which were hypothesized to represent elementary particles. These solutions had no event horizons (Einstein never accepted the possibility of event horizons) and were not black holes.
Likes Dale
I thought Einstein never accepted the possibility of singularities...Did Schwarzschild accept the possibility of event horizons?
He never accepted those either, as far as I know. But he also never accepted event horizons; he published at least two papers in the 1930s making arguments for why a gravitational collapse could never result in an event horizon.
I don't think he was aware of the possibility inherent in his solution. He died on the Eastern Front in WW I only a few months after sending his paper to Einstein.
Likes Klystron
Do you know when the first time the concept of an event horizon was conceived of, or found in the literature? I noticed that Vanadium 50 mentioned 1958, three years after Einstein died. Did Wheeler come up with it?
The Oppenheimer-Snyder 1939 paper on gravitational collapse described it, but that clue wasn't followed up for another couple of decades.
Visual Horizons in World Models
W Rindler
https://doi.org/10.1093/mnras/116.6.662
01 December 1956
This paper seeks to effect a unification and generalization of various particular results on visual horizons scattered in the literature. A horizon is here defined as a frontier between things observable and things unobservable. Two quite different types of horizon exist which are here termed event-horizons and particle-horizons. These are discussed in detail and illustrated by examples and diagrams. The examples include well-known model-universes which exhibit one or the other type of horizon, both types at once, or no horizon. Proper distance and cosmic time are adopted as the main variables, and the analysis is based on the Robertson-Walker form of the line element and therefore applies to all cosmological theories using a homogeneous and isotropic substratum.
Rindler cites a 1924 work by Eddington using “mass-horizon”.
Weyl wrote a 1921 article using the term “mass-horizon”. https://www.nature.com/articles/106800a0.pdf
I haven’t read any of these in detail to see if they actually refer to the event horizon.
Likes Dale
This term appears to refer to a property of the Einstein static universe cosmology, not the event horizon in Schwarzschild spacetime.
1. What was Albert Einstein's original concept for a black hole?
Albert Einstein's original concept for a black hole was proposed in his theory of general relativity. He theorized that a massive object could warp the fabric of space-time to such an extent that even light could not escape its gravitational pull, resulting in a region of space known as a black hole.
2. How did Einstein's concept differ from previous theories of black holes?
Einstein's concept differed from previous theories of black holes as it described them as a result of the curvature of space-time rather than a point of infinite density. This theory also predicted the existence of gravitational waves, which were later confirmed in 2015.
3. Was Einstein's concept widely accepted at the time?
No, Einstein's concept of a black hole was not widely accepted at the time. In fact, even Einstein himself had doubts about the existence of black holes, as he believed that the laws of physics would not allow for such extreme conditions to exist in the universe.
4. How has our understanding of black holes evolved since Einstein's original concept?
Since Einstein's original concept, our understanding of black holes has evolved significantly. With advancements in technology and observational techniques, we now have strong evidence for the existence of black holes and have a better understanding of their properties and behavior.
5. How does Einstein's concept of a black hole continue to influence modern scientific research?
Einstein's concept of a black hole continues to influence modern scientific research in a variety of fields, such as astrophysics, cosmology, and gravitational physics. It has also inspired new theories and models that aim to explain the mysteries of black holes, such as the holographic principle and the no-hair theorem.
  • Astronomy and Astrophysics
