Einstein's theory of gravity
  1. May 4, 2005 #1
    Hi,
    I'm stuggeling trying to understand the physics behind this. I just don't know where to start. Everything I read just goes into too much detail. And my lecturer didn't explain it well at all he basically just gave us this http://www.warwick.ac.uk/~phsep/px311/notescosmology/cosmology4-7.doc (page 6) without explaining what was going on. :confused:
    Can someone help me? :frown:
  3. May 4, 2005 #2
    selfAdjoint
    Staff Emeritus
    Dearly Missed
    This is a perfect example of something that can have easy or no math and still be confusing because the discussion is all at a higher level than the student casn support. Certainly not your fault.
    Let's start with the first section
    The familiar Newtonian inverse square formula didn't copy, but that was just in there for swank anyway. The important thing is these two statements.
    The first one says that Newton's formula has no description of how gravity spreads or propagates from one body to another. It just assumes that it is instantaneously ther even between two stars far away from each other. But this implies that things can cause other things to happen in no time at all over huge distances, and (special) relativity says that's impossible. "Spacelike related" things can interact, and simultaneity isn't defined for far apart bodies. OK? Newton's theory of gravity violates relativity.
    The second statement is something that bothered nineteenth century physicists a lot. You have thing called "mass" and its only definition's are
    [tex]F = ma[/tex]
    and
    [tex]F = G\frac{m_1m_2}{r^2}[/tex]
    And the two formulas HAVE NOTHING TO DO WITH EACH OTHER!
    Why are there two independent definitions of mass, and why do the two kinds of experimental measurements yield the same numbers up to high accuracy? It's a puzzlement!
  4. May 4, 2005 #3
    Could it be because the space displaced is related to the amount of curvature?
  5. May 4, 2005 #4
    dextercioby
    SA,the principle of equivalence is a postulate both in Newtonian gravity & GR.So there's no justified amazement.
    Daniel.
  6. May 4, 2005 #5
    selfAdjoint
    Staff Emeritus
    Dearly Missed
    Daniel, if you folow the document the OP linked to, it is going though the main logical steps in Einstein's journey to GR. When Einstein started down that path, there wasn't any Equivalence Principle. and the amazement was manifested in every nineteenth and early twentieth century physicist who could lift his nose from "the next decimal place". I am going through the document section by section to try and bring its rather perfunctory description to life.
  7. May 4, 2005 #6
    dextercioby
    I dunno how it was called (my CM teacher called "principle of equivalence"),but it was known since Newton that gravitational mass and inertial mass were the same object...If it wasn't known since then,how would the celestial mechanics have been developed...?
    Daniel.
  8. May 5, 2005 #7
    Since Newton it was known that the values for either were equal within the margin of error of tests. Einstein postulated that they would be found equal in every test because they are the same thing from different perspectives. That’s a more advanced approach that led to predictions beyond Newton. In Einstein’s view (my words), the Earth’s surface accelerates upward to maintain its position (to be in equilibrium) against inward accelerating space, like the push (acceleration) you feel against your hand when you squeeze a tennis ball.
  9. May 5, 2005 #8
    That doc doesn't look conducive to learning. I suggest you go to a large bookstore or library and look at all the laymen's books on relativity, shifting among them until you understand the key concepts like the equivalence principle.
    Or browse the web for better info. Encarta (the Microsoft software encyclopedia) has a great movie clip of the equivalence principle that is worth a chapter.
    This site is one of the most succinct I've seen. It covers the basics of the tidal force, the equivalence principle, and gravitational time dilation, all in just a few paragraphs and pictures.
  10. May 5, 2005 #9
    Zanket - I don't think Einstein thought of gravity as you have described in post 7
  11. May 6, 2005 #10
    It's an interpretation of the equivalence principle. We feel the Earth's surface accelerating upward. It's accelerating against something it's in equilibrium with, otherwise presumably the Earth would expand or shrink. I don't see anything squeezing the Earth, so I can say it's inward accelerating space. Check out free-fall coordinates here.
  12. May 6, 2005 #11
    I disagree. Taylor and Wheeler did a decent job in their text Exploring Black Holes. I hope to work on making the description easier some day myself.
    Please also note that it mass is not really defined as f = ma (this was Mach's and Euler's notion. Not Newton's). Its quite argueable that Newton's mass was defined as f = d(mv)/dt (details can be found in Max Jammers texts).
    Sure it has a description. It simply has no explaination. Then again GR doesn't either. It too has only a descripion. GR is accurate and consistent with relativity whereas Newton's isn't.
    They do not define the same thing. They define different things. One is gravitational mass while the other is inertial mass. One of the gravitational masses is active (i.e. source) gravitational mass while the other is passive (i.e. that on which gravity acts) gravitational mass. They need not have the same units and as such they don't really have to be refered to as mass. Its simply easy to refer to each as mass. The principle of equivalence states only that the two are proportional.
    Pete
  13. May 7, 2005 #12
    Zanket - what you are describing is more like in-flow theory - I can't say if IT is right or wrong since it predicts the same results as GR - but my comment was directed to the fact that Einstein didn't think of things that way - GR contemplates a static space modified (condidtioned) by matter. Inflow theory contemplates a dynamic of some sort - usually an aether.
    Pete - how could they have different units.
  14. May 7, 2005 #13
    Change the units of G and you'd have to change the units of the M's. Adjust the magnitude of G then you can use a proportionality constant to change the equality to a proportionality and still have a valid equivalence principle.
    Pete
  15. May 7, 2005 #14
    Pete - so you are saying for example "25 clubs" of gravitational mass would be equal to "20 kgm" of inertial mass, but we would then need to change the magnitude of G to G* and the units of G* would be [(M^3)/(sec^2)]/club. So fundamentally, the two entites are different animals - coincidentally equal, but not equivalent in fact.
  16. May 8, 2005 #15
    JesseM
    If they were proportional, so that any object with x kg of inertial mass will always have 1.25x clubs of gravitational mass, then it would just be a difference of units, inertial mass and gravitational mass would still be equivalent. For them to be independent, you shouldn't be able to use inertial mass to determine gravitational mass at all, just like you can't determine how many coulombs of charge on object has just by knowing its inertial mass.
  17. May 8, 2005 #16
    But the fact is - we have two separate experiments that must be satisfied in the sense that each defines a force. I think Pete is saying, its possible that the two different entities are not physically the same thing at some fundamental level.
    But isn't that where history started on this issue - with all the many experiments aimed at measuring even the slightest difference between gravitaional and inertial mass
    Recall Feynman's musings - that perhaps gravity, like centrifugal force, is in reality a pseudo force that manifests itself because we do not have the right coordinate system. This line of thought points in the direction of absolute equivalence, i.e., that G forces are in reality due to accelerations of cosmological origin
  18. May 8, 2005 #17
    JesseM
    OK, I just looked back over Pete's posts and it looks like that's what he is arguing. But actually, I'm a little confused about this, thinking about that comment you mentioned by Feynman:
    Doesn't general relativity already say this, so this isn't really a "musing" but just a description of the theory? For any coordinate system where someone is at rest and experiencing a gravitational force, can't you find another coordinate system where this is just a pseudo-force due to acceleration?
  19. May 8, 2005 #18
    Chronos
    Whose reference frame are you speaking about?
    My bad, I just saw your post JesseM.
  20. May 8, 2005 #19
    OK, good to know. My book Relativity Visualized says, "In a nutshell, Einstein's view of gravity is that things don't fall; the floor comes up!" But that's the only source I have like that.
  21. May 8, 2005 #20
    Chronos
    Gravity is not a force, it is the geometrical relationship between objects. EM fields are superimposed over that background.
