What if gravity worked differently?
In summary, this conversation is confusing because the student doesn't understand the physics behind it and the expert does not have time to explain it in detail.
  • #36
So does any other explanation - air friction, water friction, whatever, is not involved in Galileo's conception... just as the equating of Inertial force To G force won't give you an accurate measure of the fall time in a liquid.
  • #37
That's irrelevant, all that matters is that it's logically possible the gravitational force would pull different masses at different speeds, even without friction from any medium. It doesn't work that way in the real world, but logically there's no reason it couldn't. Instead of the gravitational force on an object being proportional only to its mass, it could be proportional to (mass - volume), for example, in which case there'd be something analogous to the buoyancy term even in the absence of any medium.
<h2>1. What is gravity and how does it work?</h2><p>Gravity is a fundamental force of nature that pulls objects with mass towards each other. It is responsible for keeping planets in orbit around the sun and objects on Earth from floating away into space. The strength of gravity depends on the mass and distance between objects.</p><h2>2. What would happen if gravity was stronger or weaker?</h2><p>If gravity was stronger, objects would be pulled towards each other with a greater force, making it harder for things to stay in place. This could result in planets and other celestial bodies colliding with each other, and objects on Earth feeling heavier. If gravity was weaker, objects would be pulled towards each other with less force, causing them to float or drift away from each other more easily.</p><h2>3. Would life be possible if gravity worked differently?</h2><p>It depends on how different gravity is from what we know. If gravity was significantly stronger or weaker, it would have a major impact on the physical properties of the universe, making it difficult for life as we know it to exist. However, if gravity was only slightly different, it is possible that life could still adapt and thrive.</p><h2>4. How would different types of matter be affected by a change in gravity?</h2><p>Different types of matter, such as gases, liquids, and solids, would behave differently under a change in gravity. For example, liquids and gases would spread out more in a weaker gravity, while solids would become more compact. In a stronger gravity, liquids and gases would be more condensed, while solids would be more spread out.</p><h2>5. Are there any theories or experiments about gravity working differently?</h2><p>There are many theories and experiments about gravity, including the theory of relativity proposed by Albert Einstein. Scientists have also conducted experiments in space to observe how objects behave in microgravity, which is a state of very weak gravity. However, there is still much to learn about gravity and its potential variations in different parts of the universe.</p>
  • Astronomy and Astrophysics
  • Beyond the Standard Models
