Homework Help: Elastic collision equations
  1. May 17, 2014 #1
    In a one dimensional elastic collision there are two equations: conservation of momentum and conservation of energy. by solving those 2 sets we get that the relative velocity before equals minus the relative velocity after:
    [tex]v_1-v_2=-(u_1-u_2)[/tex]
    Is this equation valid also in the general case of two and three dimensional collisions?
    i.e. is it: ##\mathbf v_1-\mathbf v_2=-(\mathbf u_1-\mathbf u_2)##
    I have difficulties trying to solve an example i made up and i will post it separately
  3. May 17, 2014 #2
    BvU
    2017 Award
    In the center of mass, a collison of two objects is one-dimensional if we do not take the extent (size, shape) of the participants into consideration.
  4. May 17, 2014 #3
    Good, but this equation derived in the laboratory coordinate system, i read it in a book.
    I understand that this equation is good for the center of mass if it's a three dimensional problem, and also for the laboratory system if it's a one dimensional, right?
  5. May 17, 2014 #4
    Yes that's correct. The logic goes like this
    * The collision in the CM frame is always 1-D so the theorem always applies in the CM frame.
    * The coordinate transform that relates the CM frame with the Lab frame doesn't affect relative velocities so the theorem always applies to the Lab frame as well.
  6. May 17, 2014 #5
    What is 1-D? is D the two or three dimensions? and if it is 1-D is negative.
    I don't understand
  7. May 17, 2014 #6
    1-D is not an equation. It means one dimensional.
  8. May 17, 2014 #7
    Even if the collision is 3-D is still the collision in the CM 1-d? i think it's 2-D, no?
    Do all 3-D collisions transform to 1-D in the center of mass? it's impossible
    I mean of course they are 1-D but the plane of the movement changes, doesn't it matter? does the equation:
    ##v_1-v_2=-(u_1-u_2)##
    Hold in CM even if the plane changes?
  9. May 17, 2014 #8
    Yes you're correct. I miss-stated the dimension. That doesn't affect the logic which is that the theorem is always valid in the CM frame so it must always be valid in any frame.
  10. May 17, 2014 #9
    But in CM it's 1-D, is it valid in Lab 3-D?
  11. May 17, 2014 #10
    Yes it is valid in any frame
  12. May 17, 2014 #11
    BruceW
    uh... why is there a negative sign there? I'm guessing the two objects have equal mass, which is why you have an equation with no masses in it. But I'm not sure about the negative sign. Maybe it is best to start with an equation of the form (momentum before=momentum after) and see where that takes you.
    edit: also, does 1 mean before and 2 mean after? or does ##u## mean before and ##v## mean after?
  13. May 17, 2014 #12
    You guessed wrong. The equation is always valid even if the masses are different and the sign is correct as is. v means before while u means after. 1 and 2 label the particles.
  14. May 17, 2014 #13
    OK, what I said before really isn't entirely correct. I should've been more careful with my statements. Only the component of the vectors along the direction of the impulse satisfy the equation. The other component doesn't
  15. May 17, 2014 #14
    BruceW
    ah, OK, I see what's going on now. yeah, I agree. It is the component of the velocity in the direction of relative velocity which satisfy that equation. Also, there is the 'trivial' case where the two objects just continue along the same course. But that's not so interesting.
  16. May 17, 2014 #15
    Note though that the component perpendicular to the impulse satisfy the same equation except for a reversed sign.
  17. May 18, 2014 #16
    BruceW
    I don't think it is possible to know the direction of the new relative velocity. Only the magnitude. Anyway, I'd say the OP'er should write down the 3d vector equations for momentum conservation and kinetic energy conservation, and maybe use the center of momentum frame of reference (for simplicity), and try to see where it takes him/her.
  18. May 18, 2014 #17
    Yes, that's correct. It's not possible to predict the direction. That was my mistake earlier in the thread. I misread the equation as being an statement about magnitudes and said it was correct. Later on I realized it was intended as a vector equation which is not correct since the direction is unpredictable. I had to come back and retract the earlier statement.
  19. May 18, 2014 #18
    haruspex
    No, as dauto wrote it applies in the direction of the impulse. In an oblique impact that is not the same as the line of relative velocity.
  20. May 18, 2014 #19
    BruceW
    well, that equation applies for the old components of velocity in the direction of the old relative velocity, and the new components of velocity in the direction of new relative velocity. So I think both our statements were a bit badly made. Also, it should be a plus/minus sign really. Anyway, it would be much better to write it in terms of vectors and inner products, so that's my advice to the OP'er if he returns.
Have something to add?
Draft saved Draft deleted
