• Support PF! Buy your school textbooks, materials and every day products Here!
Elastic collision of a glider
  • Thread starter r16
r16
42
A target glider, whose mass [itex]m_2[/itex] is 350g is at rest on an air track, a distance [itex] d =53cm [/itex] from the end of the track. A projectile glider whose mass [itex] m_1 [/itex] is 590g approaches the target flider with velocity [itex] v_{1i} = -75 cm/s [/itex] and collides elastically with it. The target glider rebounds elastically from a short spring at the end of the track and meets the projectile glider for a second time. How far from the end of the track does this second collision occur?
Elastic collision [itex] KE_{i} = KE_{f} [/itex]
[tex]v_{1f} = \frac {m_1 - m_2}{m_1 + m_2} v_{1i}[/tex]
[tex]v_{2f} = \frac {2 m_2}{m_1 + m_2} v_{1i}[/tex]
I broke it down into 2 seperate stages, a [itex] t_1 [/itex] from when [itex]m_2[/itex] goes from its starting point to the wall (a distance of [itex]d[/itex]) and a [itex]t_2[/itex] from when [itex]m_2[/itex] rebounds from the wall and collides with [itex]m_1[/itex] again.
[tex]v_{1f} = \frac {m_1 - m_2}{m_1 + m_2} v_{1i} = \frac {.590kg - .350 kg}{.590kg + .350kg} \times -.75m/s = -.19 m/s [/tex]
[tex] v_{2f} = v_{2f} = \frac {2 m_2}{m_1 + m_2} v_{1i} = \frac { 2x.350kg}{.590kg + .350kg} \times -.75m/s = -.55 m/s [/tex]
[tex] t_1 = \frac {x}{v_{02}} = \frac {.53m}{.55m/s} = .96s [/tex]
[tex] x_1 = v_{01}t = (.19)(.96) = .18m [/tex]
So in time interval [itex] t_1 [/itex] the collision occurs and accelerates [itex]m_2[/itex] from rest to .55 m/s and [itex]m_1[/itex] is still moving at .19 m/s. It takes .96 seconds for [itex]m_2[/itex] to go [itex]d[/itex] and reach the end of the track and in this time [itex]m_1[/itex] moves .18m. Then [itex]m_2[/itex] has an elastic collision with the short spring and now has a velocity of [itex] v_{2f} [/itex].
Now:
[tex] x_2 = v_{02} t [/tex]
[tex] x_1 = v_{01}t + x_{01} [/tex]
Setting these equal when they collide and solving for [itex] t [/itex]:
[tex] t_2 = \frac {x_{01}}{v_{02} - (-v_{01})} = \frac{.53m - .18m}{.55m/s + .19 m/s} = .47s [/tex]
[tex] x_2 = v_{02}t = (.55)(.47) = .26m [/tex]
I feel confident this is the correct answer; however, the book says they collide the second time at .35m. [itex]m_1[/itex] was at .35m when [itex]m_2[/itex] collided with the wall at the end of the track. I think the book may have gotten those answers confused. Or I did something incorrectly, but then I don't know what it is. Is this the correct answer?
Answers and Replies
heres how i did: assuming your numbers are right and both moving towards end;
equate times for two sliders at which collision occurs, (I omitted units cm and cm/s)
53/55+(53-Y)/55=y/19 where y is the distance travelled by slower block after collision
solving above, gives approx 27cm, and the distance to end= 53-27=26
r16
42
Agreed that the book is wrong again? I'm using halladay resnick walker fundamentals of physics. Does anybody know of more errors in the book? I'm not in an actual physics class, I'm just freelancing doing problems in my spare time so the answers in the back are the only way to know I'm understanding the material.
Assuming your velocities are right, and thats my recollection of the elastic case w/o looking it up, yea an error. That text has been around since I went to undergrad school, I should think it would be nearly error free, course they muct update their problems periodically.
You may want to pick up the Zen Of Physics, 3000.... for like 15.00 Not a stand alone text, but if you want a lot of problems to check your methods, good investment IMO.
What is the title called exactly? I am interested...:tongue2:
r16
42
Fundamentals of physics
Fifth edition
Halliday resnick walker
The question was for Denverdoc, what is the exact title of the book and where can I purchase it?
Related Threads for: Elastic collision of a glider
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
  • Last Post
