Elastic Collision of two balls
In summary, the problem involves two balls, A and B, colliding with each other. Ball A is much larger and heavier than Ball B and is initially moving with speed X while Ball B is initially moving with speed Y. After the collision, Ball A is still moving in the same direction with an unknown speed and Ball B is rebounding backwards. The problem requires finding the speed of Ball B after the collision, Bf, using the equations of conservation of momentum and kinetic energy. To make the problem easier, it is suggested to view the collision from the frame of reference where Ball A is at rest and assume that Ball A is much more massive than Ball B. This allows for a simpler calculation and the answer can be obtained intuitively
stathike
Two balls, Ball A on the left, and Ball B on the right, are moving towards each other. Ball A is much bigger and heavier than Ball B. Ball A is moving with speed x, and Ball B is moving with speed y. They collide, and an elastic collision occurs, sending Ball B rebounding backwards.
Diagrams:
Before: A---> <---B
After: A(unknown direction,probably still to the right) B---->
Terms:
Ball B final speed: Bf
Ball A final speed: Af
Ball B initial speed: Bi = Y
Ball A initial speed Ai = X
Question: What is Ball B's speed after the collision? (Meaning solve for Bf)
Assume perfectly elastic collision
(1/2)MV1i^2+(1/2)MV2i^2 = (1/2)MV^2 + (1/2)MV^2 (conservation of total kinetic energy)
MV+MV=MV+MV (conservation of total momentum)
Coefficient of restitution = velocity of separation/velocity of approach
Coefficient of restitution = Bf-Af/Ai-Bi
Since no numbers are given, the answer is in terms of symbols. I know that since it's elastic collision, the coefficient of restitution is 1. So,
[tex]\frac{B_{f}-A_{f}}{A_{i}-B_{i}} = \frac{B_{f}-A_{f}}{X-(-Y)} =1[/tex]
So,
[tex]B_{f}-A_{f} = X+Y[/tex]
I want to solve for Bf, but I don't know Af. That's the problem.
Maybe Af stays the same as Ai (meaning Ball A doesn't change speed)?
Using the conservation of momentum equation is difficult because there are no masses given, so that will just complicate it even more.
So what do I do?
Here's a hint: You are free to use any reference frame you like to view the problem. There may be a frame in which the answer is obvious. (You can always transform back to the original lab frame when done.)
Diagrams:
Before: A---> <---B
Terms:
there is a problem right here. You are using the same mass for A and B which is not the case, if I understand your question. Also, you are using the same speed for both of them after the collision, which is not the case.
Again, you are using the same mass for both particles, and you are in addition assuming the same speed for both of them before *and* after. This is not right. You have to rewrite your equations completely.
Doc Al:
Thanks for the reply. I don't quite understand what you mean. Should I see the problem from Ball A's point of view, and then use relative speeds? How would I go from there?
nrqed:
Thanks for the reply, sorry for not being clear. The equations I listed in the "relevant equations" part were just general forms of the kinetic energy and momentum equations. I forgot to put the right subscripts on them since I didn't actually use them. (I don't know if I have to?) And you're right, the masses are not the same, which is part of the problem.
Conservation of Momentum:
[tex]M_{A}A_{i}+M_{B}B_{i}=M_{A}A_{f}+M_{B}B_{f}[/tex]
Conservation of Kinetic Energy:
[tex]\frac{1}{2}M_{A}A^2_{i}+\frac{1}{2}M_{B}B^2_{i}=\frac{1}{2}M_{A}A^2_{f}+\frac{1}{2}M_{B}B^2_{f}[/tex]
Terms:
Ball B final speed: [tex]B_{f}[/tex]
Ball A final speed: [tex]A_{f}[/tex]
Ball B initial speed: [tex]B_{i} = Y[/tex]
Ball A initial speed [tex]A_{i} = X[/tex]
Coefficient of restitution = [tex]\frac{B_{f}-A_{f}}{A_{i}-B_{i}}[/tex]
stathike said:
Doc Al:
nrqed:
In principle all you have to do is to isolate A_f from the momentum equation, plug into the kinetic energy equation and then isolate Bf. You then have Bf in terms of the masses and of the initial velocities. This can be simplified if you assume that the mass of A is much larger than the mass of B. It's not clear to me that you can indeed make that approximation.
stathike said:
Doc Al:
Yes, I would view the collision from a frame in which Ball A is at rest. The way I interpret the problem, you are to assume that Ball A is MUCH more massive than Ball B. I picture one as a bowling ball, the other as a ping-pong ball.
Done correctly, this will allow you to do this problem "in your head". (Almost.)
Doing it the hard way works too! Take heed of nrqed's comments if you pursue that route.
Doc Al:
If I view it in a frame with Ball A at rest, then that means Ball B bounces back with speed X-Y (maybe absolute value of X-Y). Is this correct? Do I have to "tranform" it once I come back to the lab reference view?
nrqed:
I haven't ignored your post, I'm still working on getting this the reference frame way.
stathike said:
Doc Al:
No. What's the relative speed of B w.r.t. A? Note that X and Y are speeds, not velocities.
Do I have to "transform" it once I come back to the lab reference view?
Sure.
The relative speed of B w.r.t. A is Y-X (or is it -Y-X?)
I'd say neither.
If you and I both run towards each other at 10 mph (with respect to the ground), what is our relative speed?
Doc Al said:
I'd say neither.
Sorry if I seem a bit dense.
10+10=20 mph
So would that mean X+Y?
Yes, much better.
So, if Ball A were not moving, then Ball B would be coming towards it at speed X+Y. Ball B would bounce back at speed X+Y. So X+Y is the final answer? What, if anything, do I have to do once I come back to the lab view?
Think it through, step by step. In the ball A frame, ball B is approaching at a speed of X+Y (directed to the left). After the collision, what's the velocity of ball B?
Transform that velocity back to the lab frame and you're done.
Since Ball A is not moving, it has 0 momentum. So, for momentum to be conserved, the speed of Ball B after the collision would be X+Y. Still, not sure how to "transform" that though.
What allows you to get away with this is the realization that a tiny ball hitting a huge ball at rest just bounces back with the same speed in the opposite direction. (A reasonable approximation, given that A is much bigger than B.) I trust this makes sense to you.
So the initial velocity of ball B is -(X+Y) and the final velocity is +(X+Y).
Transforming back to the lab frame is easy. Just do the reverse of what you had to do to get to the Ball A frame. In the lab frame, Ball A had a velocity of +X; what did you have to add/subtract to that velocity (and thus to all velocities) to get to a frame where Ball A's speed was zero?
Doc Al said:
... what did you have to add/subtract to that velocity (and thus to all velocities) to get to a frame where Ball A's speed was zero?
I had to subtract X, so now I have to add X.
(X+Y)+X = 2X+Y
So, 2X+Y is the final answer.
Edit: Thank you very much.
And there you have it. :cool:
Just for the exercise, you should now solve this problem the long way. (Using the conservation laws.)
1. What is an elastic collision?
An elastic collision is a type of collision between two objects in which the total kinetic energy is conserved. This means that the initial and final velocities of the objects are equal, and there is no loss of energy in the collision.
2. How is the momentum conserved in an elastic collision?
In an elastic collision, the total momentum of the system before and after the collision remains constant. This means that the sum of the momentums of the two objects before the collision is equal to the sum of their momentums after the collision.
3. What is the difference between an elastic collision and an inelastic collision?
In an elastic collision, the total kinetic energy and momentum are conserved, while in an inelastic collision, there is a loss of kinetic energy and the objects stick together after the collision. Inelastic collisions are also referred to as "perfectly inelastic" collisions.
4. How do you calculate the final velocities of two objects after an elastic collision?
The final velocities can be calculated using the conservation of momentum and conservation of kinetic energy equations. These equations take into account the masses and initial velocities of the objects involved in the collision.
5. Can an elastic collision occur between more than two objects?
Yes, an elastic collision can occur between any number of objects as long as the total kinetic energy and momentum of the system are conserved. This is known as a multiple elastic collision, and it is commonly seen in billiards or pool games.
