cupcaked
- 5
Here's a (crude) drawing: http://i44.tinypic.com/2mg9ts2.png
A block with mass 1.5kg is pushed against a spring such that the spring compression is 0.2m. The block is then released from rest and is observed to have a velocity of 10m/s once it is released by the spring. The block then collides elastically with another block of mass 6 kg. The incline makes an angle 37 with the horizontal and is frictionless.
a) Determine the velocity of the two blocks right after the collision.
b) Determine the distance the block of mass 6kg will travel up the incline.
c) Depending on the direction that the block with mass 6kg moves after the collision, determine the maximum compression of the spring OR the distance it travels up the incline.
a) Help! I did all the work but I ended up with the initial velocities instead of getting the final velocities, how am I supposed to do this?
Pi = Pf
(1.5)(10) + 0 = (1.5)(V1) + (6)(V2)
15 = (1.5)(V1) + (6)(V2)
(1.5)(V1) = 15 - ^V2
V1 = -(6V2+15)/(1.5)
KEi = KEf
1/2(1.5)(10)^2 + 0 = 1/2(1.5)(V1)^2 + 1/2(6)(V2)^2
75 = 0.75(-6V2+15/1.5)^2 + 3V2^2
-3V2^2 + 75 = 0.75(-6V2+15/1.5)^2
-4V2^2 + 100 = (-6V2+15/1.5)^2
-4V2 + 10 = (-6V2+16/1.5)
-6V2 + 15 = -6V2 + 15
so V2 = 0
V1 = (-6(0)+15/1.5)
so V1 = 10
but those are the initial velocities... How do i find the final velocities?
Pi = Pf
KEi = KEf
so V2 = 0
V1 = (-6(0)+15/1.5)
so V1 = 10
