Elastic energy of a bent steel rod
[Math. for Physicists, M. Stone Problem 1.4]
Assume that a rod of length L is only slightly bent into the yz plane and lies close to the z axis, show that the elastic energy can be approximated as
[tex]U[y]= \int_{0}^{L} \frac{1}{2}YI(y'')^2 dz[/tex]
It is given that the elastic energy per unit length of a bent rod , [tex]u=\frac{1}{2}YI/R^{2}[/tex]
R is the radius of curvature due to the bending, Y is the Young's modulus of the steel and I is the moment of inertia of the rod's cross section about an axis through its centroid and
perpendicular to the plane in which the rod is bent.
I don't quite get the picture.
Does it mean that each infinitesimal piece is a segment of a circle R with a different center? Or should I consider the whole bent rod as a segment of a circle of radius R?
But still the infinitesimal rod length should be [tex]\sqrt{1+(y')^2} dz[/tex], so how can I get [tex]y''^2 [/tex]?
Thank you very much!
Suggested for: Elastic energy of a bent steel rod
