- #36
ehild
- 15,542
- 1,917
D is unknown, solve in terms of it. And yes, the mass of the beam is M=2mgoonking said:shouldn't the M in I =1/12*M* D^2 be 2m?
so
I =1/12*2m* D^2
so
I =1/12*2m* D^2
after doing some algebra in the angular momentum section. i get :ehild said:D is unknown, solve in terms of it. And yes, the mass of the beam is M=2m
goonking said:after doing some algebra in the angular momentum section. i get :
10 = (Vf * 1/2) + ( D ω )
seems right so far?
the D's must cancel out somewhere, I'm still trying to figure out where.ehild said:No, I do not think it is right. And you need vf, not D.
Work symbolically. Keep D and isolate omega.goonking said:the D's must cancel out somewhere, I'm still trying to figure out where.
ω = (60 D - Vf D) / 2D^2ehild said:Work symbolically. Keep D and isolate omega.
if my algebra is correct, i can simplify more by canceling out the D's to get :goonking said:ω = (60 D - Vf D) / 2D^2
correct?
goonking said:Kinetic energy :
1/2 m vi^2 = (1/2 m vf^2) +(1/2) (I) (ω^2)angular momentum:
m vi D/2 = (m vf D/2) + ( I ω)
I =1/12*M* D^2
m vi D/2 = (m vf D/2) + ( (1/12*M* D^2) ω)
which is almost correct, but you have an algebraic error.ω = (60 D - Vf D) / 2D^2
yes, the algebra was very long.ehild said:These are the correct eq uations, and M=2m.
From the first equation, you got
Substituting ##I=\frac{1}{12} (2m) D^2 ## into the angular momentum equation (m vi D/2 )= (m vf D/2) + ( I ω), you get
##m v_i \frac{D}{2}= m v_f \frac{D}{2}+ \frac{1}{12} (2m) D^2 \omega ## .
Simplifying, it results in ## v_i - v_f = \frac{1}{3} D \omega ## . I think you made the error when multiplying by the constants.
So you get Dω in terms of the velocities. Working with the energy equation, (Dω )2 appears. Substitute .
goonking said:vo2 = vf2 + (3/2) (vo- vf)2
now do should i foil the (vo- vf)2?
