How Does Electron Transfer Affect Human Net Charge?
In summary, the problem involves transferring 0.0005% of electrons from a male human to a female human, with each person having a mass of 50kg. To find the net charges on each person after the transfer, the number of electrons per kg is multiplied by the mass of the humans to find the total number of electrons on each person. Then, the number of electrons for each person is multiplied by 0.999995 and 1.000005 respectively, to account for the transfer. Finally, the number of extra or missing electrons is multiplied by 1.602*10^-19 to find the net charge on each person.
123yt
32
Human tissue contains about 3·10^27 electrons per kg of material. Suppose two humans each have a mass of 50 kg. We now transfer 0.0005 % of the electrons from the male human to the female. What are the net charges of the two humans afterwards?
1 electron = 1.602 * 10^-19 Coulombs
Took number of electrons per kg of material and multiplied it by the mass of the humans. Then, multiplied the male human's electrons by 0.999995 and the female human's electrons by 1.000005 to find the total amount of electrons on each person after the transfer. Then, multiplied both number of electrons by 1.602*10^-19 to find the charge.
This would be correct if neither person had any protons.
The problem does not specify, but I think it is reasonable to assume that both people started neutrally charged.
In order to solve this problem, don't think about how many total electrons each person has after the transfer, try to think how many EXTRA or MISSING electrons each person has; from there, you can solve how much extra or missing negative charge each person has.
What are the net charges on the humans before the transfer?
Tried assuming the people were neutral before the electron transfer:
Number of electrons per kg * Mass of a human = Number of electrons on a human before transfer
Took that number, multiplied it by 0.000005 to get number of electrons transferred, which is the number of extra and missing electrons.
Multiplied that number by 1.602 * 10^-19 to get the positive and negative net charge on each person.
Got the correct answer. Thanks a lot guys.
The net charge of the male human would be -8.5298 * 10^-17 Coulombs and the net charge of the female human would be 8.5299 * 10^-17 Coulombs.
I would like to point out that this calculation is purely theoretical and does not take into account the complexities of human biology and the distribution of electrons within the body. It also assumes that the electrons being transferred are evenly distributed throughout the body, which may not be the case. Additionally, the concept of "net charge" on a human being is not well-defined as the body is a complex system with both positive and negative charges present. Therefore, while this calculation may provide a rough estimate, it should not be taken as an accurate representation of the actual charge on humans. Further research and experimentation would be needed to accurately determine the net charge of a human being.
1. What is electric charge on humans?
Electric charge on humans refers to the presence of charged particles, specifically protons and electrons, on the surface or within the body of a human. These particles can interact with external electric fields, resulting in phenomena such as static electricity or electric shock.
2. How do humans acquire electric charge?
Humans can acquire electric charge through various means, such as friction with certain materials, contact with charged objects, or exposure to electric fields. For example, when you rub your feet on a carpet, you can build up a negative charge due to the transfer of electrons. Similarly, touching a doorknob after walking on a carpet may result in a small shock due to the discharge of built-up charge.
3. Is electric charge on humans dangerous?
In most cases, the amount of electric charge accumulated on humans is not dangerous. However, large amounts of charge, such as in lightning strikes, can be harmful or even fatal. Additionally, electric shock from contact with live electrical wires or equipment can also be dangerous. It is important to practice caution and avoid situations where large amounts of electric charge may be present.
4. Can humans control their electric charge?
While humans cannot consciously control the amount of electric charge they acquire, they can take measures to reduce the buildup of charge. For example, wearing clothing made of natural fibers, using lotion to reduce dry skin, or avoiding friction with certain materials can help prevent the accumulation of charge on the body.
5. How does electric charge on humans affect their health?
Currently, there is no evidence to suggest that electric charge on humans has any significant impact on their health. However, exposure to high levels of electric fields or electric shocks can result in various health effects, such as muscle contractions, cardiac issues, or burns. It is important to practice safety measures and avoid situations where exposure to high levels of electric charge may occur.
