Electric charges
  1. Feb 27, 2015 #1
    The distance between two small balls of the same radius and charge is r. If we release the balls they approach, touch and then repulse each other. When their distance is 4r the repulsive force is 1/20th of the initial force. What is the charge of the first ball if the second's is Q_2 = 2*10^-5 C?
    2. Relevant equations
    F = 9*10^9*Q_1*Q_2 / r^2
    Their charge after the collision: Q = (Q_1 + Q_2) / 2
    3. The attempt at a solution
    In the end I got a quadratic function but the discriminant was negativ.
    http://kepfeltoltes.hu/150227/11026697_898760020174352_224095763_n_www.kepfeltoltes.hu_.jpg
  3. Feb 27, 2015 #2
    TSny
    2017 Award
    ##20 = \frac{16Q_1Q_2}{Q^2}##. Can this equation possibly be true if you consider the signs of the charges?
  4. Feb 27, 2015 #3
    You're right. And if I write -20 instead of 20? Because the force in (2) is in the opposite direction as in (1).
  5. Feb 27, 2015 #4
    TSny
    2017 Award
    I think that should work.
  6. Feb 27, 2015 #5
    I did it. The two solutions are: -4*10^-6 C and -1*10^-4 C. Both of them are negativ. How can I decide which one is correct? Or maybe there's two correct solutions?
  7. Feb 27, 2015 #6
    TSny
    2017 Award
    I get different answers for Q2. But I think you have it set up correctly (with -20).
    To see if both solutions make sense, calculate Q for both answers. Then check if both solutions lead to the correct ratio of forces for the attraction at r and the repulsion at 4r.
Have something to add?
Draft saved Draft deleted
Similar Discussions: Electric charges
  1. Electric Charges (Replies: 1)
  2. Electric charge (Replies: 3)
Loading...
