Solving Electric Circuits: 9V Battery, AC/DC Voltage & More
In summary, the conversation discusses the concept of voltage and how it relates to AC and DC circuits. The question asks why a circuit would not work if two batteries were connected only through their positive and negative terminals without completing the circuit. The response explains that voltage is a difference in electric potential between two points and can be positive or negative depending on the reference point. It also clarifies that current will still flow in a DC circuit, but may cause a device to work in reverse. The conversation concludes with a suggestion to switch the leads on a battery to create a type of AC current.
Red_CCF
532
I ran across this question on another site but I didn't understand the answer that was given.
The question asked that if we have a circuit that connected the positive terminal of a 9V battery with the negative terminal of another 9V battery but not connecting the battery together, why would the circuit not work? Electrons doesn't go through the battery and the cations and anions that are needed to balance out the charges are present within each battery.
Also, I'm wondering what negative voltage represetns in AC and DC circuits. For example, when I use my electric voltmeter and place the black line (normally placed the negative terminal) on the positive terminal of a battery and using the red line and placing it on the negative terminal, I get a negative voltage reading that is equal in magnitude to the voltage of the battery. I understand that in AC circuits that negative voltage means that the voltage is heading in opposite directions. But the thing is in a DC circuit a negative voltage means that the circuit won't go. Why is this? Are these two negative voltages taking about different things?
I just graduated high school so I would appreciate it if you can answer my question in a simple fashion
Thanks for any help that you can provide.
The battery voltage is quite literally the difference in electric potential between the two terminals of the battery. Let's say, for example, that we have a 9 V battery. What this means is that the electric potential of the + terminal is 9 V above the electric potential of the - terminal (when the battery is fully charged).
Now, because of the way the voltmeter works, it always tells you the difference in potential between the red lead and the black lead. Therefore, if you place the red lead on the + terminal, and the black lead on the - terminal, then the red lead will be at a potential that is 9 V above the potential of the black lead. Hence, the difference (red minus black) will be + 9 V.
Conversely, if you place the red lead on the - terminal and the black lead on the + terminal, then the red lead will now be at a potential of 9 V below the black lead. Hence, the measured difference (red minus black) will now be -9 V.
Not really. As I described, voltage is not a "thing" that "goes" anywhere (perhaps you were thinking of current?). Voltage is a difference in electric potential between two points in space. In an AC circuit, these potentials vary with time, in such a way that the voltage (potential difference) osciallates sinusoidally.
No, it doesn't. Besides, what is positive relative to one reference point could be negative relative to another reference point, as illustrated in the example below.
Let's say you first measure the battery voltage by placing the red lead on the + terminal and the black lead on the - terminal. Then you do it a second time, switching which lead is on which terminal. You get different answers because you changed what you were measuring:
In the first instance, you were measuring the potential of the + terminal relative to the - terminal. This is positive.
In the second instance, you were measuring the potential of the - terminal relative to the + terminal. This is negative.
The answer to your question is, WHAT circuit? You haven't made a complete circuit. There is no closed conducting pathway for charges to flow along. You have two batteries in series, that are ready to be connected to something. But so far, they haven't been.
I don't think I quite understand the bolded...
But, If Voltage exists, that means there is a potential difference between the terminals.
If there is a potential difference, a circuit will have current "pushed"
through it as long as the circuit is complete. It does not matter if you
assign - or +. Current will flow. It might mean that the electric motor
that you hooked up to the battery runs in reverse from what you expected.
But if you switch the leads, the motor reverses. I used a motor so that you
would realize that the current would switch directions if you reversed the leads.
A light bulb would not lead to this realization unless it was an LED that allows
current to flow in only one direction.
I hope I understood this properly and did not confuse you.
As an aside, if you could swith the leads on the battery 60 times every second
you would have a type of AC current from a battery. Maybe this helps.
oops I just read the above... I may have repeated some ideas.
Thanks for the replies
But in that case can you explain what negative voltage really is? I have a lot of misconceptions about negative voltage. Right now I think negative voltages is like those in electrolytic cells, which is voltage that must be added to make something work but I know this concept is wrong; however I've yet to find a good explanation on what it is. Does current still flow when we have negative voltages in AC and in DC and how does it differ from postiive voltages?
Here is the circuit diagram that someone who also asked this question drew:
battery one (positive) <-------|
battery one (negative)-unused |
light bulb
battery two (positive)-unused |
battery two (negative) >-------|
[QUOTE/]
the batteries are not hooked together but are placed in the same direction. Experimentally I know this would not work, but I don't understand why. Electrons flow via conducting wire from the anode to the cathode of a battery but not through a battery so why would the redox reaction of the voltaic cell not go and produce a voltage? The electrons flow from one side to the other through the wire so why must the wire be connected to the terminals of the same object?
The above example is another concern I have with the idea of voltage. In a conventional current, assuming that the negative terminal is 0V, a positive charge would lose potential energy (and gain kinetic) which would explain why it is moving to the negative terminal. But if we are using a negative charge, which moves from negative terminal to positive terminal, wouldn't it mean that the negative charge is flowing from a low potential to a higher potential (where negative terminal = 0V, positive terminal = positive voltage)?
So if I reverse the leads on a voltmeter, there is still current? Then why must everyday objects like flashlights (not using LED bulbs) have casings where the battery must match the terminals indicated on the casing? Wouldn't it be convienent if we can place the battery however we want?Thanks for any help that you can provide
If the voltmeter is hooked to a potential diff. (battery). If it is a needle voltmeter the needle will deflect in opposite directions if you change the leads to the battery. On a digital, it will read the same voltage, just + or -. The casing inside flashlights contain contacts that fit the post and the flat end of the battery. If you put the batteries in the wrong way you won't make contact with the metal contacts in the flashlight. So you have to put them in a certain way so you have a complete circuit (because you will make contact with the metal parts in the flashlight.Yes it would be more convienent. But my take is making the contacts so they fit certain terminals of the battery (post v. flat side) insures good contact. If both contacts in the battery were flat, and both sides of the battery were flat, you might not get certain contact. Thats why lots of battery operated devices have springs with contacts. The springs "push back" to ensure good contact.
My take anyway.
Oh btw, I find electrochemistry rather confusing. Voltaic stacks make sense to me, but the batteries today seem complex. So I just sit on the fact that batteries contain a potential diff. without delving into the chemistry as deeply as you are. Diff types of + and - ions in diff. batteries moving about might create confusion with the designated sign for voltage and terminals and such.
I humbly await the day someone can come up with a battery that can store energy in a relatively small volume for a long time. Hydrocarbons do a wonderful job of storing energy, it would be great if a batteries could do the same. In Texas, they actually shut down wind turbines because they don't have enough transmission lines to get the electrical energy to houses, etc... You can't store that energy, you have to use it pronto.
That's right. If a negative charge is put into a region of space where an electric field exists, if it's near the negative terminal then it has a more NEGATIVE POTENTIAL but a GREATER POTENTIAL ENERGY. The negative charge will then move spontaneously toward the HIGHER potential, and when it does it will lose POTENTIAL ENERGY (like a falling ball in a gravity problem).
In each one of the batteries, the chemical reaction requires that electrons enter one side and leave the other side. Otherwise, there will be no net chemical reaction in that battery.
Your diagram didn't get drawn because you put a backslash in your QUOTE tag.
light bulb
You actually will get a very small amount of energy out of this arrangement. What will happen is that the half-cell reactions will occur at each electrode. As this happens each electrode will acquire a net charge. This net charge will then prevent the half-cell reaction from further continuing due to simple electrostatic repulsion. It does not take very much charge at all to do this. The only way for the electrode half-cell reactions to continue is if there is some mechanism to continuously "drain" the excess charge. This is done by a net transfer of some positive ions inside the battery in the same direction as the net transfer of electrons.
In other words, in normal operation of a battery not only is there an electronic current through the wires of the load, but there is also an ionic current through the electrolyte of the battery. Both currents are essential for proper operation of the battery in order to prevent the electrodes from becoming charged (which would stop the reaction). Your arrangement blocks the electrolyte current.
Thanks for the reply
Can you explain how a net charge builds up in each battery (or the two half cells on separate batteries) and why a repulsion force would accumulate?
Thanks
You have a current (briefly) going from one half-cell to the other, so charge accumulates by dQ/dt = I. And there is a repulsive force simply by Coulomb's law due to the accumulated charge.
But how does both batteries get a net negative charge. If the batteries were initially neutral in the first place, then shouldn't one get negative and the other get positive? Thanks
Yes. Remember there are different reactions at the anode and the cathode.
But then how can the electrostatic force be repulsive if the charges are unlike? Or do I have a misconception?
Yes, you have a misconception. Whether or not the charge on the anode is attracted to the charge on the cathode is irrelevant. What is important is if the charge on the anode repels the oxidation reactants away from the electrode and if the charge on the cathode repels the reduction reactants away from the electrode.
So with a zinc- copper voltaic cell, in the cathode of one battery the Cu2+ is repelled and in the anode of the other battery the NO3- is repelled?
I don't remember the specifics of zinc copper cells, but that is the basic idea.
My dad tried to explain this to me but I'm not sure if it's right since he hasn't touched this for 20+ years.
He said that, in a copper - zinc cell with NO3- ion as the anion, the NO3- ion would repel the electrons at the cathode because the presence of electrons produces an excess charge (as the electrons don't originate in the same battery, they are extra). But my question is, if there is an excess negative charge then how come zinc ion isn't attracted from the anode to the cathode half cell to balance things out? Is it because the anode is balanced already and wouldn't move? Also how come the NO3- ion doesn't repel the electrons all the way back but just enough so that it stays on the electrode?
Thanks
OK, I read up again to refresh my mind. Here is what happens:
1) Some zinc metal leaves the electrode and dissolves into the solution, increasing the amount of zinc ion in solution and leaving electrons in the electrode.
2) The electrons flow to the copper side.
3) They attract copper ions in the solution which electroplate onto the electrode, reducing the amount of copper in solution and using up the electrons.
4) Now the zinc solution has a net positive charge which pushes zinc away and thus keeps any more zinc from going into solution. Similarly the copper solution has a net negative charge and pulls the copper back and thus prevents any more copper from plating onto the electrode. The reaction stops.
Oh so the Zinc ions prevents more zinc ions from being formed and the copper become copper ions to balance the charge. Does the net negative charge also repel the electrons?
Thanks so much for going through all this trouble to answer my question!
I hadn't thought about that, but you are absolutely correct. The negative charge of the copper salt solution and the positive charge of the zinc salt solution would tend to prevent step 2 above from happening. So the lack of a return current acts to prevent all three steps of the normal process.
1. What is the difference between AC and DC voltage?
AC (alternating current) voltage is a type of electrical current that continuously changes direction, while DC (direct current) voltage flows in only one direction. AC voltage is commonly used in household appliances and power grids, while DC voltage is often used in batteries and electronic devices.
2. How does a 9V battery work?
A 9V battery works by using chemical reactions to produce a flow of electrons, which creates an electrical current. The battery has a positive and negative terminal, with chemicals inside that allow electrons to flow from the negative terminal to the positive terminal, creating a circuit.
3. How do you solve electric circuits?
To solve an electric circuit, you need to use Ohm's Law, which states that the current (I) flowing through a circuit is equal to the voltage (V) divided by the resistance (R). This can be represented by the equation I = V/R. By using this equation and applying it to each component in the circuit, you can calculate the voltage, current, and resistance at different points in the circuit.
4. What is the role of a resistor in an electric circuit?
A resistor is a component in an electric circuit that limits the flow of current. It is used to control the amount of current that flows through a specific part of the circuit, and it can also be used to lower the voltage in a circuit. Resistors are commonly used to protect electronic devices from receiving too much current, which can cause damage.
5. Can you use AC voltage with a DC device and vice versa?
In most cases, no. AC and DC voltage are not compatible with each other, and attempting to use one type of voltage with a device designed for the other can damage the device or cause it to malfunction. However, some devices, such as power adapters, can convert AC voltage to DC voltage for use with specific devices.
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
  • Electromagnetism
