Generating Electric Currents Through Bouncing
In summary, the concept of generating an electrical current by bouncing two conductors off each other is not feasible due to the small force and momentum of electrons. The force of electrical attraction between the nucleus and electrons in an atom is much greater than any force that can be generated in this manner. A battery starts an electrical current through a chemical reaction that produces ions and allows electrons to flow freely between half cells, completing a circuit.
cam875
228
Out of curiosity is it possible to generate a split second of an electrical current which would be more of an electrical signal by literally boucing an electrical conductor off of another electrical conductor, such as copper hitting copper sending the electrons flying down the current or would this take too much energy or something.
Firstly, electrons don't operate with usual Newtonian mechanics. But even if they did, you have to think about how momentum works. Momentum is mass multiplied by velocity (p=mv). If you have an electron moving at 1000m/s, it still only has a mass of about 9.1x10^-31 kg, so its momentum is only 9.1x10^-28 kg·m/s.
Momentum and force are related by time (F=p/t). The force exerted would be tiny, even if the time taken to slow from 1000m/s to 0m/s was 0.1 milliseconds, you're looking at a force of 9.1x10^-28 Newtons. The attraction force (Coulomb's law) says that F=(q1·q2)/(4pi·E0·(r^2)), where E0 is the permittivity of space. Using the Bohr radius (5.291x10^-11 m) and the electron/proton charges (1.609x10^-19 C, negative for electrons) we can calculate that the attractive force between the electron and nucleus of a Hydrogen atom is around 8.3x10^-8 N, which is tens of orders of magnitude higher than the force of deceleration we calculated above.
In short, we can basically say that the force of electrical attraction between the nucleus and electrons in an atom is much much greater than any force you can reasonably generate from hitting two pieces of copper together.
ok cool makes sense so now I am going to ask how does a battery start an electrical current. thanks in advance and for the good answer above.
A battery works with a chemical reaction, performing what is basically the opposite of electrolysis. Salts and metals react to produce ions. The electrons flow freely between each "half cell" of the battery. When there is no circuit, the electrons have nowhere to go and don't pass between the cells. When there is a circuit, the electrons flow producing an electric current.
1. How does bouncing generate electric currents?
Bouncing generates electric currents through the conversion of mechanical energy to electrical energy. When an object bounces, kinetic energy is transferred to a piezoelectric material, causing it to deform and generate an electric charge.
2. What materials are used to generate electric currents through bouncing?
Piezoelectric materials, such as crystals, ceramics, and polymers, are commonly used to generate electric currents through bouncing. These materials have the ability to convert mechanical energy into electrical energy.
3. Can any object be used to generate electric currents through bouncing?
Yes, any object that can create a repeated motion or impact can be used to generate electric currents through bouncing. However, the size, weight, and material of the object may affect the amount of current produced.
4. What are some potential applications of generating electric currents through bouncing?
The generation of electric currents through bouncing has potential applications in renewable energy sources, such as harvesting energy from footsteps or vibrations in buildings. It can also be used in electronic devices, such as self-powered sensors and wireless charging systems.
5. Are there any limitations or disadvantages to generating electric currents through bouncing?
One limitation is that the amount of current produced may be relatively small, so it may not be suitable for powering larger or more energy-demanding devices. Additionally, the durability of piezoelectric materials may decrease over time with repeated bouncing, leading to a decrease in efficiency.
  • Electromagnetism
  • Electromagnetism
